CEL Oxygen Sensor 2001 Honda Accord
Old Mar 25, 2011 | 11:10 AM
tdsilk's Avatar
Default CEL Oxygen Sensor 2001 Honda Accord
Hello,
I have a 2001 Honda Accord EX 2dr 4cyl with a CEL warning. I had autozone read the warning and they told me that it is a 420 code. After a bit of research I decided to try replacing the O2 sensor near the catalytic converter under the car. It's has another near engine. In an attempt to remove the sensor I was unable to manually unscrew it due to rust, so I sprayed some liquid wrench to loosen to bolt. After letting it sit overnight I started the car and the CEL was gone. Unfortunately it reappeared after 30 mins. of driving. So my question is: Is this a clear indication that the CEL is caused by the O2 sensor and replacing it should remedy the problem.
note: I just remembered that I installed a new radio and removed the NEG battery terminal. Could this have anything to do with the CEL also?
Thanks,
Troy
Old Mar 25, 2011 | 06:53 PM
WHEEELMAN's Avatar
Default Re: CEL Oxygen Sensor 2001 Honda Accord
P0420 - Deterioration of the Catalytic Converter.
Replacing the o2 sensor won't help. It's the cat.
Radio install has nothing to do with your error code.
Old Mar 25, 2011 | 09:13 PM
JamesB1985's Avatar
The downstream o2 may set a DTC too if the catalytic converter is not doing it's job properly.
Old Nov 29, 2011 | 10:56 AM
MaggieK1001's Avatar
I was just informed by my mechanic that the "catalytic converter" in my Staten Island New York Dealer bought 2001 Honda Accord is California Compliant and that escalates the price to $1400 - is that possible?
Old Nov 30, 2011 | 08:39 AM
StreetsideStig's Avatar
Perhaps. Cats are very expensive. They're made with platinum. I would go to a muffler shop for it, though. The dealer will wring you dry.
Sloburn
May 19, 2016 10:35 AM
cholder919
Oct 19, 2011 12:41 AM
BobCT
Dec 21, 2005 06:06 AM
