Problem with swap b16a3 - revs out
Old Mar 25, 2011 | 07:56 AM
performs's Avatar
Default Problem with swap b16a3 - revs out
Just swapped a b16a3 in my hatch when I start the car up it automatically revs out, anyone know what some of the causes for this may be? Any and all help is appreciated
Old Mar 25, 2011 | 08:00 AM
RLW's Avatar
RLW
Default Re: Probem with swap b16a3
Please explain "revs out"
Old Mar 25, 2011 | 08:03 AM
performs's Avatar
Rpms shoot to max n attempt to stay
Old Mar 25, 2011 | 08:14 AM
Former User's Avatar
Default Re: Problem with swap b16a3 - revs out
Check whether the throttle cable is too tight and holding the throttle plate open. Also clean the throttle body, if it is sticking open.
Old Mar 25, 2011 | 08:25 AM
performs's Avatar
Gonna try another throttle body and see what happens, current is cleaned throttle cable disconnected but still maxs out rev, I'm think it's fractured some place possibly cuz I can't figure out why it's doing this at the moment will post results with another throttle body in a few mins
Old Mar 25, 2011 | 08:29 AM
Check the TB and IM gaskets and make sure they are torqued to spec.
Old Mar 25, 2011 | 10:32 AM
luvmihatch's Avatar
u gotta air leak some where. like they said check tb, ask gaskets etc etc.
put your hand over the tb and see if it stalls out.
if u smoke light up a cig, and blow the smoke around some things to see if u can see where its getting sucked in.
88si
Feb 28, 2009 05:27 PM
monkalotamus
Nov 15, 2006 06:31 PM
mkinpwrat12g's
Sep 1, 2005 07:12 AM
frostcivic
Oct 12, 2004 03:52 AM
ic108
Jan 28, 2002 10:24 PM
