D16A SOHC VTEC ?'s Swapping into 91 wagon
Finally got my engine, d16a sohc vtec with a24a auto trans on it, will this trans work or will i have to use the one from the d15b? I have a 91 wagon 2wd with a d15b dual carb on it right now ( almost out) thanks.
I spoke with boomslang today, and they said they don't make a conversion harness for an auto? wtf.... i'm ready to buy everything but just don't what to buy, well at least i know now to get the p28 for auto!! i have the obd1 engine harness, just need the ecu conversion harness and resistor box ( which one)?
Boom slang said it depends what auto trans i use? please help someone.
Help dammit or just give me a dam link!! forum's have become no help the only help you get is did you SEARCH, if anyone know's some anything about how to do this swap please post. thanks
im trying to look around too
let me just get this straight you want to run a obd1 d16a vtec with the same tranny 92-95 right...but you dont know what mount to use?\\
if it were me id run the motor that came with the wagon instead of dealing with all that bull ****
run a p28 auto and just buy a jumper harness for the ecu and dizzy
also you will need to convert your car to mpfi
hope this helps
hope this helps
hope this helps
hope this helps
BXPhoto
Jun 9, 2015 02:13 PM
rexizbest
Jul 27, 2004 03:10 AM
