SiR Water pump on LS help
Old Mar 24, 2011 | 10:33 PM
PROJECT_HATCH59's Avatar
Default SiR Water pump on LS help
I got a tech question if anyone can help. I have an ls b18a block I'm rebuilding. I don't have cash to piece up a new water pump for it but I have a water pump off my SiR block. The difference I notice is that the pulley on the SiR is slightly larger than the stock ls. I know that the cams spin at 1/2 the crank,so will the different size water pump have an affect on my engine performance? Can i use the SiR water pump or will over time it have an affect on performance? Any advice is helpful.
Old Mar 25, 2011 | 04:25 AM
kyden's Avatar
Default Re: SiR Water pump on LS help
you can use that water pump, but you'll have to use a gsr/itr belt.
Old Mar 25, 2011 | 08:00 AM
What about tensioner pulleys and cam gears? Keeping those stock from ls would be fine? I
l'll go ahead and use that belt,but do you mind telling me why I would need to use that belt over the stock ls belt? Just wanna learn for my own good.
Old Mar 25, 2011 | 07:20 PM
wayneshondawork's Avatar
im not so sure about tht man,i would triple check and dnt go on just advise,i learned not to go cheap the hard way...no offense kyden but im sure ud do the same
Old Mar 25, 2011 | 09:01 PM
yea. I guess I'll just wait and piece up on a new pump. no point putting a used one on anyway when I'll have to pull the engine out again and do another rebuild. Thanks.
soon2bdropped
Jul 22, 2007 11:33 AM
DA is best
Mar 18, 2007 07:22 PM
19sec beast
Mar 31, 2006 04:40 AM
alfee
Nov 28, 2005 09:37 AM
Dancing is Forbidden
Oct 10, 2003 01:24 PM
