Hondata
I think it should work...but I think the engine you put in a car has to be the same year or newer than the car.
Meaning any OBD1 swap into a post-1995 car is illegal...at least in Cali.
well...
the wiring harness that came with your swap is not going to work. essentially you would need to buy an obd-2 harness that goes all the way down to the ecu instead of connecting in the engine bay. then you would need a jumper harness to convert the obd2 wiring harness to obd1.
ALSO your going to need some other obd2 parts like distributor. someone else elaborate. im not up on my obd1 engine into obd2 chassis swaps.
i guess i should revise my question to say: Can I convert my OBD II car to and OBD I car, buy replacing the ecu and engine with their OBDI counterparts. I want to do this because the Hondata works better with OBD I cars. I have heard (from Shawn) that the OBD II coversion of the Hondata is not as effective as the straight OBDI.
- yes
-im tempted to call bs... but i wont because its always a possibility that im wrong in saying that hondata will work just as well on an obd2 car using an obd2->obd1 harness.
- yes
