Building a B20Z for nitrous
Old Sep 27, 2002 | 07:56 AM
Dokta's Avatar
Default Building a B20Z for nitrous
I am in the process of collecting parts to build up my B20Z to handle a huge shot of nitrous. I was aiming for a 150 to 200 shot. Already on my shopping list are JE pistons, eagle rods, arp fasteners (head, wrist pin, etc), steel head gasket, and a blueprint and balance. What I wasn't sure about is how much the stock sleeves would be able to handle. Are the stock honda B20Z sleeves made out of iron, or are they coated? I am trying to decide if I should resleeve the block or just get a block guard. Do all block guards have to be welded in? I was worrying about the heat from the welding compromising the integrity of the sleeves and block.
Old Sep 27, 2002 | 08:09 AM
stizzit's Avatar
Default Re: Building a B20Z for nitrous (Dokta)
For headgasket, you probably want to go with a cometic. Now you want to do all this on a b20 which is NOTORIOUS for having weak sleeves so you have to be VERY carefull, one mishap and its all over. I know from experience (check sig) so listen. whatever you do, use a STOCK ECU or an engine management system do NOT, i repeat, do NOT use a chipped ECU. I don't recommend a block guard but no they do not have to be welded in, you need to have them presfit (or hammered) in and then you MUST bore and hone. I would recommend having your block pinned or posted by a shop (unless u know how). Lastly you WILL need a progressive rate Nitrous controller. Introducting your motor to 150+ shot of nitrous is a big no no, thats when things start to break. I was going to build a progressive rate nitrous controller, still want to, just gona take some time tho.
Old Sep 27, 2002 | 08:15 AM
Dokta's Avatar
Default Re: Building a B20Z for nitrous (stizzit)
So the B20's do have weak sleeves. I am beginning to think that a complete resleeving will be required to pull this off safely. I have also heard bad things about block guards.
Old Sep 27, 2002 | 09:40 AM
stizzit's Avatar
Check out some pictures of B20 cracked sleeves sometime, notice they all crack in just about the same place and its usually cylinder #3 (hottest).
Old Sep 28, 2002 | 08:35 AM
Dokta's Avatar
I may send my block to golden eagle to get it resleeved. Besides the sleeves, does anyone know any other weak points in the B20Z?
Old Sep 28, 2002 | 12:36 PM
non-VTEC's Avatar
accually i thought B20 block has one of the strongest sleeves/blocks. all 4 cylinders are siamesed togeather. the B18B/B18C/B16 blocks have individual cylinder sleeves.
i dont think i have seen cracked B20 block...........unless they have been put to major stress............i'd like to see this.
anyway to answer your questions. if your serious about running that big of a shot i would highly recommend re-sleeving the block. also stainless steel intake and oversized stainless exhaust valves. a good head gasket to hold the pressure. ARP head bolts, low compression forged pistons (9.5:1) and good strong connecting rods (crower, eagle, carillo) and of course fuel (injectors, fuel pump)..............
good luck.........
Old Sep 28, 2002 | 07:55 PM
TREVER's Avatar
Default Re: Building a B20Z for nitrous (non-VTEC)
stock b20 sleeves, high comp. and nos do work together. Im running 11.2, 84.5, stock sleeves and a 120 shot. I would not recomend this to everyone, I'm trying to see how much the sleeves can handle. For reliability I would sleeve your block to begin with
Old Sep 28, 2002 | 10:32 PM
miller's Avatar
Default Re: Building a B20Z for nitrous (TREVER)
golden eagle my friend , that is the best thing you can do
jamescb77
15
Jun 28, 2007 02:25 PM
NITROUSHONDA
Jun 16, 2005 09:25 AM
Odiedogcx
18
Oct 29, 2004 01:41 AM
hybridpatient95
Oct 27, 2004 12:17 PM
