93 LS ecu on 94 LS?
Old Mar 24, 2011 | 11:51 AM
lyzer227's Avatar
Default 93 LS ecu on 94 LS?
I was woundering if i would have a problem if i put an 93 PR4 into my obd1 car with a 94LS in it (and the ecu and the car are both 5 speed). I know the only difference is that the trans on the obd1 has a electronic speed sensor and the PR4 doesnt have that. will that give me a check engine light for the speed sensor?
Old Mar 25, 2011 | 07:54 PM
fonkernuckle's Avatar
Default Re: 93 LS ecu on 94 LS?
I have an obd-1 pr4 running in my 94 ls and no check engine light and kinda prefer the pr-4 since my p75 made it idle higher than what ti suppose to be set at (rpm wise).
Old Mar 26, 2011 | 06:01 AM
HAMOTORSPORTS's Avatar
Yes, it will run it just fine. The only MAIN difference between the two is the idle routine is slightly different.
live_again_integra
Jan 23, 2007 05:42 PM
Integspeed21
Oct 11, 2004 10:44 PM
kun3racer
Mar 15, 2004 12:36 PM
93, 94, ecu, ls
