shuts down in drive only!!! wtf???
i have a 94 accord vtec automatic and for some reason it shuts down in any forward gears when i give it too much gas.. ive tried a new distributor, ecu,tcm, and main relay and nothin helped its not throwin any codes either so is there anyone who could help with this issue??
thanks!
thanks!
By tha way it idles fine n does fine in reverse n revs fine in neutral also if I just barley push gas pedal it will run better but not perfect... someone Please help wit this its driving me insane
Tune up items up to date? Any stored codes? Got a few more after you answer these.
Then help me understand a little better what you mean by "it shuts down in any forward gears when i give it too much gas"
Then the last one for free, oh wait they are all free
, now I know why I'm poor...does this only seem to happen when that car is warm-normal op temp?
Basically I did a swap n replaced everything to convert to vtec it was running great then I wiredin vtec n start getting into it a lil more n that's when it started acting up so I unhooked vtec n still does it so I got another ecu n tcm n main relay.. no change. As for tha temp thing it does it cold n warm and if I push tha pedal in more than like an inch it starts spudderin n shuts down then takes a few to start back n sumtimes rite back up
Glad you figured it out...good luck
porter1929
Jun 23, 2012 06:26 AM
