? about high impedence injectors with obd0?
I have a 91 civic dx d15b2 dpfi and Im in the process of switching to mpfi, I have pm6 ecu can i use obd1 injectors without resistor box with pm6 ecu? i have researched and it is an unclear answer some say it will fry the pm6 ecu is this true?
Also I have obd1 dizzy from d15b7 is it compatable with pm6 ecu? I have already made a jumper harness for obd0-obd1.
you can use the OBD1 injectors without a resistor box with the PM6 - no problem
you cannot use the OBD1 distributor with the OBD0 PM6 ECU - they are not compatible - OBD0 ECU requires OBD0 distributor - OBD1 ECU requires OBD1 or OBD2 distributor
thanks for clarifying, what dizzy should I look for an Si or would a Hf dizzy also work?
Pancho2193
Mar 2, 2013 06:35 AM
the4g4d
Jan 13, 2007 04:18 PM
redcrx187
Jul 25, 2004 01:00 AM
