Cruise Control
Old Mar 23, 2011 | 12:00 PM
curtie94's Avatar
Default Cruise Control
In my 1991 honda accord when i set my cruise control all of the lights come on but my speed won't hold unless I keep pressing accel. It doesnt set right when I press the set button like all of the other cars I drive. I adjusted the actuator cable and still no luck. Please Help Me.
Old Mar 23, 2011 | 01:13 PM
curtie94's Avatar
Default Re: Cruise Control
somebody
Old Mar 23, 2011 | 05:08 PM
poorman212's Avatar
Any stored codes, that would be the best place to start.
Old Mar 23, 2011 | 06:06 PM
curtie94's Avatar
i tried it at higher speeds and it sets but my car drops exactly 5 MPH before catching, it goes back to the speed I set it to.
Old Mar 24, 2011 | 03:06 PM
poorman212's Avatar
Any codes?
After that there are a few tests/adjustments that might be able to help. Do you have a manual for this, suggests getting one. There are sites where you can download a free one.
Old Mar 29, 2011 | 09:20 AM
Raf99's Avatar
Look under the hood on the drivers side and you'll see a black and silver UFO shaped thing.
past this link if you wanna see a pic -
http://www.angrypandaparts.com/catalog/!BrbGGH!!mk~$%28KGrHqMOKjUEvL60NPYsBLzle-jud!~~_1_1556_1.JPG
It works on a suction based system with air hoses attached to it. Follow the hoses that come off of this unit (except for the one going straight down into the body) and make sure there are no leaks in these hoses.
Sounds like you cannot keep a tight seal due to a vacuum/air leak.
Cheers
Old Mar 30, 2011 | 02:33 PM
Jmb106jr's Avatar
Been following your post and it inspired me to do a little research. I have a 92 accord wagon that had the same problem. I adjusted the cable at the actuator under the hood. It took all of 5 mins and problem solved.
SirFerret
Honda CR-V & Element
Dec 17, 2013 05:26 PM
curtie94
Oct 25, 2011 07:12 AM
strngblkman
Jul 15, 2010 01:42 PM
RyanPm
Jun 20, 2009 05:28 AM
