Quick Clutch question
Old Sep 27, 2002 | 05:42 AM
CXHatchback's Avatar
Default Quick Clutch question
What is a sign of a bad clutch, when it grabs low or grabs high on the pedal? Thanks
Old Sep 27, 2002 | 06:29 AM
EightOhOne's Avatar
Default Re: Quick Clutch question (CXHatchback)
that could be a sign of a master cylinder going bad......do you ever have to build up pressure in the clutch to shift? does the clutch slip at high rpms?
Old Sep 27, 2002 | 09:10 AM
Default Re: Quick Clutch question (EightOhOne)
What could be a sign? I was just wondering if it's bad when it grabs low or grabs high. It never slips and I dont' have to "build up pressure in the clutch" to shift.
Old Sep 27, 2002 | 09:12 AM
1.8monster's Avatar
you can tell if the clutch is slipping by putting it in a higher gear and just flooring it. if the rpm's goes up and you're still moving at the same speed then its slipping. if not then your clutch is still good.
Old Sep 27, 2002 | 09:16 AM
Default Re: Quick Clutch question (1.8monster)
I know mine's still good, but as it wears, does it grab low or high? Like if I just got a new clutch, would it grab high or low on the pedal?
Old Sep 27, 2002 | 09:34 AM
lightning's Avatar
It usually grabs high.
Old Sep 27, 2002 | 09:10 PM
Default Re: Quick Clutch question (lightning)
Thank you
langjairicer
May 1, 2010 12:08 AM
ic89
10
Oct 15, 2006 03:14 PM
Grease Monkey
Jul 15, 2004 05:39 PM
steve_s
Jan 26, 2003 03:10 PM
