k20 b16 gsr cable tranny dizzy nitrous koyo axles
Old Mar 23, 2011 | 09:20 AM
viper_linx's Avatar
Default k20 b16 gsr cable tranny dizzy nitrous koyo axles
revxc
Old Mar 23, 2011 | 10:00 AM
The 209's Avatar
Default Re: k20 b16 gsr cable tranny dizzy nitrous koyo axles
u better save those parts for me fool
Old Mar 23, 2011 | 01:43 PM
sanchoem1's Avatar
Where are you located?
Old Mar 23, 2011 | 08:15 PM
viper_linx's Avatar
sac
Old Mar 24, 2011 | 12:38 PM
viper_linx's Avatar
up
Old Mar 26, 2011 | 08:17 PM
viper_linx's Avatar
455
Old Mar 27, 2011 | 09:22 AM
viper_linx's Avatar
tt
Old Mar 27, 2011 | 08:31 PM
ALLMOTORCRX20's Avatar
If only you were closer.....
Old Mar 28, 2011 | 08:02 AM
viper_linx's Avatar
ttt
Old Mar 29, 2011 | 08:12 AM
viper_linx's Avatar
tttt
Old Apr 1, 2011 | 08:42 AM
viper_linx's Avatar
ttt
Old Apr 1, 2011 | 08:42 PM
viper_linx's Avatar
tttt
Old Apr 3, 2011 | 12:28 PM
viper_linx's Avatar
bumpo
Old Apr 4, 2011 | 11:26 AM
viper_linx's Avatar
ttt
Old Apr 5, 2011 | 10:24 AM
viper_linx's Avatar
top
Old Apr 5, 2011 | 04:17 PM
viper_linx's Avatar
ttt
Old Apr 5, 2011 | 05:51 PM
viper_linx's Avatar
Old Apr 5, 2011 | 05:57 PM
viper_linx's Avatar
PAPER ! PAPER!
Old Apr 6, 2011 | 05:15 PM
sh!ft's Avatar
Who the fack changed my title?!
thats not a gsr trans. gsr transmissions in cable form only came into production from the years 92 and 93 and had a completely different construction than the one you posted pictures of. sorry to bust your bubble but thats a regular LS transmission.
Old Apr 8, 2011 | 08:57 AM
viper_linx's Avatar
explain construction? so your saying that theres 2 diff casings for a cable tranny? and how u think its not a gsr?
Old Apr 8, 2011 | 09:14 AM
sh!ft's Avatar
In the early 90's before 94 to be exact, there were two types of casings made for a cable transmission. One with an internal 3 fork on 2 pole setup, and one with a 3 fork 3 pole setup. The 3 pole setup was only introduced on some of the 4 door integras as well a few of the other special models from the years 92-93. These units came with what you call detent bolts. A spring loaded bolt with a ball bearing that held the top portion of the pole on the outside of the casing. 12mm in socket size. Not to mention the 3 pole setup was designed exactly the same as a newer 96+ hydro unit. That's why everyone likes the 3 pole cable gsr or 3 pole cable setups because you could directly swap newer hydro gears into the casing without having to convert to hydro. The 2 pole setup has no parts that can be mix matched like the 3 pole does. Plus the bearings are totally different. The one you have shows a typical 90-91 bearing on it. A single bearing. As to a cable gsr would have 2 bearings on the countershaft.
Old Apr 8, 2011 | 09:40 AM
viper_linx's Avatar
tx good to know
Old Apr 10, 2011 | 08:58 PM
viper_linx's Avatar
ttt
Old Apr 11, 2011 | 07:21 AM
viper_linx's Avatar
yyyhggvhbk
Old Apr 11, 2011 | 03:05 PM
viper_linx's Avatar
klkjlkj
