Honda S2000 Honda S2000
NEED HELP (Buddy Club Related)
Old Mar 23, 2011 | 07:38 AM
BLANCOh22a4's Avatar
Default NEED HELP (Buddy Club Related)
whats good guys-
i recently installed BC racing spec coilovers on my '06 and the fronts are not going as low as they should be. I believe i maxed them out and i still have a solid 1 finger gap between the tire and the fender. I am not looking to completely slam my ride but am just testing waters. I have not messed with the preload but i turned the coilover clockwise all the way to the max. (I was expecting the car to be sitting on the ground by this adjustment?) I know it's something probably small, stupid and noobish but could someone help a brother out?
Old Mar 23, 2011 | 07:54 AM
Boots's Avatar
Default Re: NEED HELP (Buddy Club Related)
give them a day or two to settle..they might go lower with the weight on the car on them for a couple days...and suspension components almost always settle lower then initially set
Old Mar 23, 2011 | 08:01 AM
Black S2K's Avatar
did u preload the control arms? after u put the coilovers on loosen the uper control arm jack the spindle up to the hight u think the car will be ridin at and then tighten fully
Old Mar 23, 2011 | 07:05 PM
FogDarts's Avatar
Are you sure you are adjusting the height and not the preload? I have BC race on my AP1, and I've had to raise the car twice to keep the tire from rubbing in the front. When I first installed mine, the car was on the ground. You should be able to get yours as low as anyone would want with these.
white4doorsi
Feb 15, 2005 07:19 PM
TougeCoupe
Jul 10, 2004 07:05 AM
crxforum
Aug 24, 2003 10:59 PM
Red_Si
Jun 25, 2003 09:41 AM
djay86
Jul 31, 2002 08:06 AM
