Lower arm question. Please help
Will the integra gsr front lower arms fit on an eg? Just got done building my girls car and it has a ton of sway when we turn. Someone local is selling their front lower arm and sway bar. Is it a direct replacement to put the gsr arms and sway bar? Will it go right in or will it not work or will I have to modify. I'm assuming itll working since it's the same chassis but not 100% and just want to make sure before I purchase these
Another thought.
The front EK subframe (6th gen) can be swapped into a 5th gen Civic. This will allow you to use the stamped steel LCA's off the 6th gen 99-00 Civic Si and save a little weight. You'll also need to change the rear engine mount bracket for this to work. ... and this can also be swapped into the DC2/DB Integra for some weight savings.
LextasyIS300
Aug 24, 2008 12:32 PM
