Small rims = lower car?
Old Mar 22, 2011 | 08:53 PM
Choppin's Avatar
Default Small rims = lower car?
whats up. Jus a quick question i have a 98 sedan lowered 2 inches on stock steelies and stock tire size. I am satisfied with the drop but would like to know if i was going with 16inch rims and a low pro tire would my car go lower to the ground? Would it create a gap cause now i have none?
Old Mar 22, 2011 | 09:20 PM
my99ekcoupe's Avatar
Default Re: Small rims = lower car?
If the rims are going to be smaller than what your steelies are then yes, the car chassis will be lower to the ground.
It's common sense.
Old Mar 22, 2011 | 10:15 PM
crxmadness's Avatar
Type in your wheels and tires sizes and this calculator will tell you if you go lower, higher, or stay the same:
http://www.miata.net/garage/tirecalcold.html
It's common sense.
Not necessarily, it all depends on tire size.
Old Mar 22, 2011 | 10:18 PM
raidacaipo's Avatar
I dont think it will go lower but I think that it will look or appear lower. I had 16 inch rims on my dropped civic with some thin tires and it looked dropped..
Old Mar 23, 2011 | 05:55 AM
Red_Army's Avatar
if you have smaller rims you should have bigger tires to match stock wheel size. so no it shouldn't.
Old Mar 23, 2011 | 06:01 AM
pmptwst17's Avatar
It probably looked dropped because you dropped it...
Old Mar 23, 2011 | 11:32 AM
raidacaipo's Avatar
well duh that too lol but what I meant to say was that it looked more dropped then my 15" rims with bigger tires 205/50/15
Old Mar 23, 2011 | 12:27 PM
TwoFaced's Avatar
16's with like 40 series tires might drop it a bit, not 100% sure. Either way as someone mentioned above...the 16's with low profile tires will make it appear lower than it is anyways.
Old Apr 11, 2011 | 12:25 PM
_d0nnnnnn's Avatar
I lowerd my ek 3inches and I just picked up some 13"bbs mesh for them. Do you guys think thats a bad idea? Im affraid that it will become to low and beat the **** out of my fenders.
Old Apr 11, 2011 | 12:51 PM
lunareg's Avatar
that depends on the tire size, your suspension ect...
Old Apr 11, 2011 | 02:06 PM
civicjunkie17's Avatar
Try to always keep the wheel size.. For example I have 14s on my car and the aspect ratio of the tires I have are 65. With 16s I would go with a lowest of 50, because any lower than that then you'll have speedo issues.
Old Apr 11, 2011 | 02:41 PM
Libertariat's Avatar
Ek Forever y0!
If you buy the appropriate tire for your 13-14-15-16" wheel you can keep the original ride height.
For 16's you want a 205/45/16 to be closest to OEM spec. 205/40 and 205/50 also work, 205/50 is the stock ITR tire size for the 16" wheel.
There is a tire for all the wheel sizes mentioned in here to keep the original total wheel/tire diameter about the same. Going far outside of this diameter really messes with your fuel economy, speedometer accuracy, etc.
Old Apr 11, 2011 | 03:21 PM
Exactly what I was going for. Well put
Old Apr 11, 2011 | 03:43 PM
TwoFaced's Avatar
Will the brakes fit in a 13?
People had issues with the 13 version of the HX wheels...dunno what they're from but I know it was a brake clearance thing.
Old Apr 11, 2011 | 05:27 PM
Vindicator9000's Avatar
318 Curves, 11 miles
Yep, I was thinking that too. I seriously doubt 13" wheels would clear EX brakes; not sure about other trim levels.
Old Apr 11, 2011 | 06:50 PM
TwoFaced's Avatar
I think it might look a little odd IMHO as well.
That'd be like 65 series tires to make it even level out slightly. I think BBS mesh in a 13 would be better fitting for an ef?
To each their own.
GOTRICE12
Dec 20, 2012 09:58 AM
Blazeone
Honda S2000
19
Feb 22, 2005 05:19 PM
sloz64now
14
Nov 24, 2004 10:42 AM
02AccordBigBoi
Oct 26, 2004 10:18 PM
Preludekid5
Aug 12, 2002 10:56 PM
