89 hf Crx with poorMans type r swap help 8(***
Old Mar 22, 2011 | 08:16 PM
daprolistic's Avatar
Default 89 hf Crx with poorMans type r swap help 8(***
So I have a 89 Crx which is a obd0 and I swApped I'n a poormans type r Gsr block cable b16 tranny and b16 head the only problem having is the wiring harness cuz the car is a obdo dual point. And the shift linkage? Am I able to use Integra da's linkage and harness cuz I don't really wanna order hasport I dumped all the money I had on the motor.Plz help me out. Can I use a jumper harness?
Old Mar 22, 2011 | 08:24 PM
crx_si-r's Avatar
Default Re: 89 hf Crx with poorMans type r swap help 8(***
looks like you should have done some research before diving in head first. to answer your questions:
1. you can use a 90-93 integra shift linkage BUT you have to have it cut and welded to fit.
2. no you cannot use the integra harness
3. you must convert your stock harness to MPFI and then add in the vtec wiring
hatchydohczc
Sep 25, 2012 04:08 AM
jdmsuckah
Sep 2, 2010 01:35 PM
justin1785
Jun 25, 2010 09:30 AM
crazydude107
May 20, 2008 06:40 PM
chipper
10
Jun 5, 2002 07:43 PM
