2001 accord rear end noise
I have a 2001 accord 2 door 6cyl automatic that has recently been making a clicking noise from the driver side rear. I only hear the noise when its warm out not when its cold. I got underneath today and checked everything and didnt see anything wrong. It happens going forward and in reverse i start to hear it when i apply the brake and then it continues after. I checked the brakes and everything seems ok i cant really figure out what it is and its relatively loud any suggestions would be appreciated thanks in advance.
So, it clicks all the time or only after you apply the brakes?
sounds like brakes to me.
If it clicks all the time, could be a wheel bearing.
did you check your tire for anything stuck in the treads?
Ya i checked the treads for anything that could be stuck and basically what it does is when its warm out all of a sudden i will start hearing the noise and when i hit the brakes it goes away and when i release them it immediately comes back but when its cold or cool out its perfect with no issues.
redm3turbo
Jun 14, 2011 05:04 AM
Landshark68
Jul 15, 2006 09:12 AM
