AL FS: 98.Civic.LX.4dr / Built.B16A.Swap / Black.on.Gray
1998 Honda Civic LX / Flamenco Black Pearl
The vehicle is SOLD!
Mileage: Body – 140xxx
Engine – 2832 Miles
Asking: $8,000 - Price is negotiable.
Contact: Email me straight to my phone at kyocasey@gmail.com, or a PM.
Exterior:
Spun Supamesh- 16” wheels (green) w/ Toyo Proxes FZ4 – 205/40/RZ16
Brembo- rotors w/ EBC Redstuff- ceramic pads w / Stock calipers
Seibon- carbon fiber hood w/ AeroCatch- locking hood latches
Type R style front grill
Depo- black housing headlights
Depo– Clear fog lights
Depo– Red/Clear taillights
Benen– Black front tow hook
Alarm/Keyless entry
Interior:
Front seats from a 95 Civic hatch
Original rear seats
NRG– 320mm Sport Leather Steering Wheel w/ Red Stitch
NRG– Quick Release Kit - Black/Black Ring
NRG– Short hub
Canadian spec custom SiR gauge cluster w/ carbon fiber bezel
Skunk2– short shift w/ energy suspension bushings
Skunk2– weighted shift ****
Type R shift boot
Amber lit climate control
ICE:
Kenwood KVT-512 7-Inch Wide Indash Monitor with USB/iPOD Direct Control/DVD Receiver
Sony front and rear speakers
Can include subwoofer box w/ two 12” 1200watt Sony Xplod subwoofers w/ Sony 1200watt Amp
Suspension:
Benen– Tripod 3-point, front upper strut tower bar (purple)
Function & Form– Type 1 adjustable coil-over
ASR– Subframe brace (purple)
Blackworks– Rear lower control arms (purple)
Lighting:
Conquer– 4300K 55watt Bi-Xenon (high&low) HID bulbs w/ Ballasts – Headlights
No name brand– 3000K 35watt HID bulbs w/ mini balasts – Fog Lights
Engine:
JDM B16A – w/ B16 Transmission w/ LSD
Shaved and cut valve cover / Powdercoated Victory Violet
Skunk2– Pro series intake manifold w/ Hondata thermal intake manifold gasket
Skunk2– Composite fuel rail w/ stock injectors
Stock throttle body
Password:JDM Dry Carbon Fiber PowerChamber Intake
Mishimoto– coolant hoses
Blackworks– Twin core radiator w/ slim fan
Hasport– EK Stock Replacement Mounts (U70A-Race)
Civic Type R N1 Crank pully
Rywire tuck harness
Hondata S300 tunned by Johnny Adams of Crestview FL
Engine Internals:
B16A bored .20 over
JE Proseal Rings
Eagle H-Beam rods
Clevit race bearings / main bearing / thrust bearing
Micropolished factory crank
Supertech 11.5:1 pistons
Supertech valve gear
ITR cams 98 spec on PR3 gears
Cometic N/A headgasket
ARP head studs
Ported and polished PR3 head
Gates racing timing belt
Clutch net stage 3 clutch w/ 6 puck sprung hub
Exedy 9lbs flywheel
Exhaust:
Megan Racing– 4-1 B-series header
Megan Racing– High flow cat
HKS High Power– cat back exhaust system
The Bad:
As with any used car, there are some scratches and small dings. The worst part of the exterior is the driver side fender, a cabinet fell on it and left a pretty good dent. And the driver side of the front bumper has a warp, not too bad though, it was there when i got the car. The interior has many painted pieces (black). The carpet is rather stained from spills. I do not have the trunk liner, its all bare.
The last photo below shows the bumper and fender damage.
Photos:
Cluster, compliments of Bloody Hatch.
^Fender and bumper damage.
Dyno run / Tuning:
http://www.youtube.com/watch?v=fu5pe...er_profilepage
Engine – 2832 Miles
Exterior:
Alarm/Keyless entry
Interior:
Original rear seats
NRG– Short hub
Type R shift boot
ICE:
Suspension:
Lighting:
Engine:
Stock throttle body
Rywire tuck harness
Engine Internals:
B16A bored .20 over
JE Proseal Rings
Eagle H-Beam rods
ARP head studs
Exedy 9lbs flywheel
Exhaust:
The Bad:
Photos:
Dyno run / Tuning:
Jdm=Ep3
May 19, 2010 06:24 PM
christhereefer
Feb 19, 2009 01:49 PM
bugger ill
Dec 9, 2008 04:12 AM
