96 civic b18a1 code 20 eld issue
Old Mar 22, 2011 | 09:55 AM
billard's Avatar
Default 96 civic b18a1 code 20 eld issue
hi i have 96 civic b18a1 swapped and it runs drive but cels 20 41 and no speedo wiring is legit ecu is legit
Old Mar 22, 2011 | 10:19 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 96 civic b18a1 code 20 eld issue
What have you done to fix the CELs?
Old Mar 22, 2011 | 02:44 PM
billard's Avatar
i had a couple broken plugs and they got mixed and fucced all up by a bad hydralic on a hoist i used 96 to 00 civic manual to correspond wire colors to sensors then peicing obd1 sensor plug from extra James harnesses with proper pin-out always double check or even triple check still have eld issue all the new cels are correspondent with each other eld,o2, and no speedo
appreciate any help
Old Mar 22, 2011 | 06:59 PM
billard's Avatar
44 veiws and no one knows
dookeye
Jan 24, 2010 11:53 AM
ensracer
Oct 31, 2004 08:07 AM
