Can I / Is it a good idea to take this cover out?
Old Mar 22, 2011 | 09:39 AM
HeavyRopes's Avatar
Icon2 Can I / Is it a good idea to take this cover out?
I was wondering, in my ek, it has the half radiator but theres a plastic panel that blocks airflow going through the other half of the front grille area...
I was wondering, would it be better to take it off *cooling purposes* or is it something i Dont want to take off? /*so as not to tamper with the O2 sensor...
hope to get an answer soon
all opinions are welcome
-Roppo
Old Mar 22, 2011 | 10:07 AM
Linked's Avatar
Default Re: Can I / Is it a good idea to take this cover out?
it wont interfere with the O2 sensor, and might even cool the ambient temps under the hood even,
but does it direct any airflow to the radiator?, i know its not neccesary to, but it might do just that
Old Mar 22, 2011 | 10:13 AM
HeavyRopes's Avatar
I dont believe that it is, considering that it is set nearly Behind the radiator itself. right where the fan mounts.
Old Mar 22, 2011 | 11:28 AM
TunerN00b's Avatar
The black plastic block off plate?
You want that there for the best cooling.
Any air that can enter the engine bay without going through the radiator reduces the amount that does travels through the radiator. The lower the pressure in the engine bay, the more effective the radiator becomes.
Old Mar 22, 2011 | 11:46 AM
94EG8's Avatar
Seagull Management
If you tend to hit puddles the water usually ends up all over the distributor. Honda didn't put it in there for no reason.
Old Mar 22, 2011 | 11:57 AM
project93hatch's Avatar
it will keep you engine bay cleaner too!!! if you leave it. i dont have one and my sh*t gets dirty but then agin i live in washington where it rains all the time!!
what is the exact name for that thing i need to get one
Old Mar 23, 2011 | 09:24 AM
HeavyRopes's Avatar
Idk what it is called, never seen it on a hatch until this one that i got, But if u find out what there called let me know, need to get a new one. want it looking fresh and will cut out spots for my Foglights
wunfstgsr
Jun 17, 2014 02:54 PM
matt203
May 14, 2013 08:16 PM
axis11
10
Mar 5, 2013 12:34 PM
ej6hatchie
Jun 4, 2008 10:54 AM
cecknight
Jul 13, 2002 06:52 AM
