h22 obd2 swap ecu
Old Mar 21, 2011 | 07:14 PM
01sdime's Avatar
Default h22 obd2 swap ecu
ok im doing an h22 swap in my 96 accord and i really want to keep it obd2 so i can pass inspection. ive done a lot of ressearch on this and havent come up with many options. im never gonna find an obd2 p13 and i dont know of any way to get around the immobilizer on the p5p/p5m. ive found some ppl saying that there is a way to disable the immobilizer, but no one is willing to say how. so my question is whats the difference between the poh (f22 vtec ecu) and the h22 ecu's? as far as i know both motors are very close, the main difference as far as i know is the dohc on the h22. can i get a POH ecu and put a h22 base map in it and run the car?
Old Mar 22, 2011 | 04:30 AM
accordmatt's Avatar
Default Re: h22 obd2 swap ecu
h22 redlines at 8200rpm ur stock accord is 6200 so u will not be able to run full potential. immobilizer from what l understand there are some ecu shop/ a certain guy(sorry cant think of name) that can remove this for a price. l think phearable or someone could do this. but if not done correct u will be sitting on the side of road. right now lm using my accord ecu on h22 runs fine but its a automatic ecu so probally lacking fuel mileage and tcu code is thrown and l cant run it further then 6200 rpm.
Old Mar 22, 2011 | 09:08 AM
CD5Accord_Corey's Avatar
Im also running F22 vtec ecu but on jdm h22 to auto trans. It will run fine. Redline will be different.
Old Mar 22, 2011 | 02:04 PM
01sdime's Avatar
well if you tune the poh ecu with the h22 map cant you also move the redline up to 8200rpm? or is there no way to interface with the ecu to fix the redline
Old Mar 22, 2011 | 02:17 PM
TheMuffinMan's Avatar
He knows where you live!
You cannot chip an OBDII P0H ECU........therefore you cannot put an H22 map on it. You cannot reflash it either.
You also have an integrated TCU whereas the earlier models (94-95) had a separate TCU. You need to run the correct ECU/TCU for the motor to work properly.
Old Mar 22, 2011 | 06:55 PM
01sdime's Avatar
so can you map any honda obd2 ecu... i know it can be done on other cars such as subarus with with just a speical cable and a lap top? and is the tcu just for the auto trans or is that for the 5 speed too?
Old Mar 22, 2011 | 07:28 PM
GhostAccord's Avatar
The K series OBD2 ECU can be tuned via Hondata K-Pro. However, it won't work on an H22. Unless you want to look into switching to a distributorless ignition system and swapping over a few other sensors and switches as well.
Yes the TCU is only for automatic transmissions.
Old Mar 22, 2011 | 09:06 PM
Those ECUs feature a reflashable onboard EEPROM chip, your ECU does not have that ability. Certain ECUs can be reflashed (the 06+ S2000 is one of those) in a similar fashion to the Subarus, most other OBDII system you have to run a piggy back for tuning.
Old Mar 23, 2011 | 02:10 PM
01sdime's Avatar
so the accord ecu should run the h22 with out any cel but it wont be at the out put the h22 should be... so as long as i keep the motor mostly stock i should be able to run an obd1 p13 and swap in the accord ecu just to pass emissions.... is that correct? also will it be as simple as swaping the ecus or is there other wiring issuse i will run into from obd1 and obd2?
Old Oct 26, 2011 | 08:42 PM
roboaccord22's Avatar
I have a 97 accord ex with obd2 h22a in. when i had my f22 ecu in all it did was flash the cel light at me because of a ghost random mis. in all cylnders. because of the aib or the butterflys that open additional runners in the intake manifold adding more aire than fuel tricking the ecu that its misfireing but its realy not. therefore it will dump alot of fuel into motor u WILL smell raw gas like i did and wont pass emmissons... U WIIIILLLL need a 38720-p13-a12 ecu from a 1996 prelude there not hard to find u just need to know where to look.... i get all my parts from canadian salvage yards and parts store for the odd thing like the ecu they seem to have everything all the time... just hard to comunicate sometimes when they speak french and have a canadian accent..
Old Oct 27, 2011 | 10:47 PM
holmesnmanny's Avatar
Why did you bump this 7 month old thread ?
Old Jul 13, 2023 | 01:18 PM
Mydadhadahonda's Avatar
Ok so from what I gather
my 37820-p0h-l02 ecu non/Tcu vtech ecm (try to say that 5 times fast) is not chippable, so where I cannot remap it?
or can I open up a spare one, replace the chip, and capacitors while I’m in there and get it to perform better?
currently planning to follow these footsteps if it’ll work
import_tuner13
Nov 12, 2011 01:03 AM
hondatuningboi96
Jun 12, 2006 12:26 PM
djSALIX
Jul 1, 2005 08:24 PM
