GSR in a 92 Integra engine is acting weird at 1500rpm
Old Mar 21, 2011 | 06:38 PM
HondaTom87's Avatar
Default GSR in a 92 Integra engine is acting weird at 1500rpm
okay so I got my swap up and running and it seems to run strong except at 1500 rpms it seem as if there is some sort of 2 step. it bounces at 1500 and strugles to get past it but if I am more than a quarter throttle it doesn't do it.
I am also throwing an ECT code and my temp gauge is alway cold. I think there may be air in my cooling system but could that cause the throttle issue?
any help or ideas would be great
Old Mar 21, 2011 | 07:37 PM
mark@silbernage's Avatar
Default Re: GSR in a 92 Integra engine is acting weird at 1500rpm
TPS have a bad spot?
Old Mar 21, 2011 | 08:29 PM
mouab18c1's Avatar
Fix your ect to see if it resolves the problem. If not then at least you've eliminated that already.
Old Mar 21, 2011 | 10:14 PM
redflaredcrx90's Avatar
ok what yr is the car what yr is the motor and what wiring harness did you use. if its a stock gsr out of a 94-01 integra . you might have to switch the throttle body wires a round the stock tb opens up the oppsite way for a ls or b16
Old Mar 22, 2011 | 07:23 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
Did you connect the TPS and MAP sensors backwards?
AND ALWAYSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS, ALWAYSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS clear any codes before troubleshooting something else!
Old Mar 22, 2011 | 10:05 AM
earfejj's Avatar
Could be a dirty IACV as well.
Old Mar 26, 2011 | 12:15 PM
HondaTom87's Avatar
not dirty lol the plug was in but not making contact.
it was the IACV. the damn thing just wasn't making a connection. so I de-pinned the plug and crimped on two new connectors and plugged it back in. problem solved.
once that was solved the code for the ECT went away too.
now I just have to put a thermostat in the car cause the previous owner of the motor removed it completely.
but to answer all other questions
I don't clear codes until the I know the problem is fixed and most of the time I won't even have to clear the code once it is fixed.
I am running a 92 integra engine harness That I made and vtc wiring is done on a sub harness that I also made.
every issue as far as the codes are concerned is fixed so I am very happy about that.
Thank you for the help guys
b20vteclsintegra
Oct 27, 2011 11:33 AM
b20vteclsintegra
Oct 27, 2011 02:20 AM
OrangeTeggy
Jul 9, 2011 10:36 AM
Blue00Si
Mar 19, 2009 05:03 PM
b18c1wes
Dec 7, 2004 02:50 PM
