B18b swap ef/ed sedan swap help!
Old Mar 21, 2011 | 06:38 PM
kingsnake692005's Avatar
Icon3 B18b swap ef/ed sedan swap help!
I have an 88 civic sedan, 5spd dpfi & obd0
I kno imma have to do the mpfi swap but thats no biggie.
Im getting a deal on a b128b for $400 & i get everything for the swap except tranny, clutch, flywheel & shift linkage.
Should i run this obd1 or convert the engine to obd0 with 90-93 teg parts?
If i kept it obd1 what would I need?
What kinda mounts or could i use some kinda stock mounts?
could i use the 94+ axles/int shaft 0r do i need 90-93?
should i buy shift linkage or get 90-93 linkage & cut it 2-3/8?
Old Mar 21, 2011 | 06:43 PM
Aesthetic Gains's Avatar
Dos Pupusas
Default Re: B18b swap ef/ed sedan swap help!
If you have absolutely no intentions of upgrading the engine (cams/pistons) don't waste your money for obd1. Save it up and buy the rest of the stuff and swap the B18 in there. The rest of your questions can be answered in the FAQ of this forum.
Old Mar 21, 2011 | 06:47 PM
i do have plans of upgrading & going boost. I ant find anything about obd1 b18b into an ef
Old Mar 21, 2011 | 06:53 PM
i needa & wanna swap because my car is running on 3 cylinders & i dont wanna put money into that motor when i can get qa good b18 with less than 150k when my motor has 227k
Old Mar 21, 2011 | 08:44 PM
D16SiHatch's Avatar
Originally Posted by kingsnake692005
I cant find anything about an obd1 b18b into an ef
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/detailed-b-series-into-crx-ef-civic-parts-list-more-2769325/
Old Mar 21, 2011 | 08:48 PM
KINGVEM^^ED6's Avatar
pm member clipsed he can help with all your mpfi and obd1 upgrades if your goingfor boost go obd1 man gl
Old Mar 22, 2011 | 03:54 PM
I def wanna go obd1 for boost & bc i heard its better for tuning
Dr1ft1ng0wns
Apr 4, 2010 09:15 AM
EFlove91
19
Oct 28, 2009 07:36 AM
BOMBCRU
Oct 4, 2005 01:41 PM
JDMonty
Oct 30, 2003 08:05 PM
