Car dies at stop signs...mechanic says distributor?
Old Mar 21, 2011 | 05:38 PM
JohnnyWash1's Avatar
Default Car dies at stop signs...mechanic says distributor?
Hey all,
I just bought a 1992 Civic DX. The car drives perfectly, until you come to a stop sign. The car will sputter and die, eventually. The previous owner said her mechanic diagnosed it as a faulty distributor; does this sound right? I would think a bad distributor would affect driving as well. Any insight?
Old Mar 21, 2011 | 05:43 PM
vici0us's Avatar
Default Re: Car dies at stop signs...mechanic says distributor?
Seems like you got an idling problem of some sort.
Old Mar 21, 2011 | 05:52 PM
grumblemarc's Avatar
The Grumpiest
Any CELS-Check Engine Lights?
Old Mar 21, 2011 | 06:11 PM
Sorry, not enough info in OP. No, there are no other symptoms, including CELs. The car seems normal until you come to a stop.
Old Mar 21, 2011 | 06:17 PM
honda.lioness's Avatar
Does this only happen after say 20 minutes of driving? If so this does point to a failed ignition coil (a part of the distributor). The distributor is the Achille's heel of this generation. Consider replacing the igniter at the same time. Use only OEM parts for anything ignition related. They pay for themselves in longevity.
The sensors in the housing are also known for failing. Fortunately the OEM dizzy housing is very inexpensive for the DX.
Old Mar 21, 2011 | 06:29 PM
vansxskater's Avatar
Kind of sounds like your SS sensor.
Old Mar 21, 2011 | 09:01 PM
I have only driven it home, however, I did not start doing this until I was almost home. During the first few minutes, while warming up, the car seemed to be fine at stops. It wasn't until I was almost home that it did this.
Old Mar 21, 2011 | 09:06 PM
Former User's Avatar
If the problem only happens when stopped, then you likely have a low idle problem. Does the CEL work? If so, try cleaning the IACV.
Old Mar 21, 2011 | 11:10 PM
RonJ, I was hoping to hear from you. It only happens when idling. Do you think it could be the distributor? I'm trying to figure out the mechanic's thinking.
Old Mar 22, 2011 | 12:02 AM
EK_MaGz88's Avatar
could be a bad IACV-Idle Air Control Valve.. If you have a buddy with the same car, try swapping the IACV.. they are too expensive to risk buying one and end up having the same problem.. haha
Old Mar 22, 2011 | 05:51 AM
This is enough to point strongly to a bad coil. You can check it. From my experience I would just replace it and probably the igniter, too.
Old Mar 22, 2011 | 06:01 AM
foo fighters's Avatar
Sounds to me like a PCV valve or TPS.
Old Mar 22, 2011 | 09:20 AM
SOHCCody's Avatar
Clean the IACV, check your idle, if not id say replace the coil
Old Mar 22, 2011 | 10:48 AM
Thanks guys. I think the coil has been replaced recently, as I found the old one in the glove box. I will purchase an igniter.
DRAGANDB1
Aug 9, 2018 06:19 PM
AndyD
Dec 22, 2014 03:13 PM
Jhicks
Jan 28, 2012 07:08 PM
b20turbocivic
Apr 25, 2008 08:54 PM
