2000 accord CEL 300-3004 P1399
Old Mar 21, 2011 | 05:20 PM
Hypochondriac's Avatar
Default 2000 accord CEL 300-3004 P1399
I have a weird problem, my sister improperly stored a 2000 4 cylinder Honda Accord for about 8 years. She started driving it about 8 months back.
The CEL came one, cand gave codes 300-304 and P1399. Took it to a mechanic, we replaced the wire set, spark plugs, distributor cap, and rotor. Fuel pump cost a total of $700
The problem went away for about 5 days, but now it's back. Any idea what else it could be? Ran a fuel injector cleaner, but made no difference. Now the mechanic is saying we may need to change the fuel injectors or gas tank since there might be debris in the tank that keeps clogging the fuel injectors.
Old Mar 21, 2011 | 05:35 PM
phootbag's Avatar
Default Re: 2000 accord CEL 300-3004 P1399
First step is to stop taking the car to that mechanic. Spark plugs don't go bad from sitting, nor do caps rotors or wires. Fuel pumps won't go bad either.
If there is questions about debris in the tank, remove the fuel sending unit and look. See for yourself. This could save a TON of money.
How long after starting the car did the code appear? Is there a drivability symptom along with the codes? Can you tell the car is misifiring?
Old Mar 21, 2011 | 05:45 PM
When the problem first showed up, we could easily tell it was misfiring. Now that the light is back onreally can't tell, but the accleration is terrible. How hard is it to remove the fuel sending unit? I know very little about cars. The light came on after 5 days or about 80 miles
Old Mar 28, 2011 | 02:28 AM
yonipoka's Avatar
try adjusting the valves... that's what i did and it goes away, i already put 2000 miles on it and it passed the smog, by the way my 01 accord has 320,000 miles on it.
Doug6465
Feb 4, 2024 05:12 PM
efkilla
May 10, 2011 11:14 PM
Hypochondriac
Feb 21, 2011 07:15 AM
FREQUENCY 24.7
Jun 8, 2010 11:10 PM
Dropped90Integra
Jul 26, 2005 05:09 AM
