Crush Washer??
I've changed my oil several times but have not replaced the crush washer. I've never had a car with a crush washer and the idea seems silly. The manuals say replace the washer with every oil change but why? It's a washer, why replace it?
so you don't over tighten the drain plug... if you dont replace it over time you will strip out the plug hole on the oil pan and then you'll be replacing your whole oil pan
They're meant to be crushed one time, but people tend to reuse them. Being as inexpensive as they are, it's best to just replace it.
I've been using a plastic drain plug washer for months, and a few oil changes, without any issues.
I bought spares but keep forgetting to take them out when changing the oil. I ve reused my aluminum washer for maybe 5 years now. No leaks and the bolt isn't stripped because I use a torque wrench
I can feel a new crush washer compressing when I torque the drain plug.
I've reused them many times, but will replace it when it starts to drip.
Although they're really only supposed to be used once, I used the same crush washer several times before switching to a plastic one.
Never used a torque wrench, never stripped my oil pan, and never had any leaks.
The HOnda's manual say to repace the washer every oil change. YOu don't have to replacee every oil change. Just check the condition of it, and the washer look very flat then it need to replace. You don't really need a torque wrench to tighten the bolt. I just use my hand to tighten it, but not extremely tight. Ottherwise bad thing would happens..
Although I have worked on other peoples cars where the plug was torqued so much that the washer deformed into the threads and couldn't get it off. I'm guessing in that case there might have been strippage.
NOOdS
13
Nov 28, 2011 02:56 PM
