transmission question
Old Mar 21, 2011 | 04:46 PM
matix246's Avatar
Default transmission question
So i was wondering if you can make a 5 speed manual, a 6 speed? or if you can get the 5th gear bigger so it has a better top end and cruise at lower RPMs.
99 acura cl 2.3 manual trans.
also a bearing or differental? is going out so would it be cheaper to rebuild it cuz it doent need gears and stuff, or just drop a used one in their?
anyhelp or input would be great thanks
Old Mar 21, 2011 | 05:13 PM
phootbag's Avatar
Default Re: transmission question
If you can find a shop that would make a new set of gears I don't see why you couldn't. Unless there wasn't enough room.
As far as rebuilding, you'd need to know if the problem is gears or bearings making the noise. Bearings are cheap with only the labor to remove, disassemble, replace and reinstall being the major portion of the bill. Gears are a bit more expensive, especially the large differential gear(s).
Rebuild vs. Used/Reman is debatable. It depends on the price of the rebuild, the price of a used trans and the price of a reman trans. You need to call around.
Old Mar 21, 2011 | 05:14 PM
phootbag's Avatar
To clarify, increase the gear ratio, not add a 6th gear to the set. That would not be practical. Neither would changing the gear ratio, if you ask me....
Old Mar 21, 2011 | 06:12 PM
specialone70's Avatar
ya, that wont really help you very much. im assuming you are doing this for better mpg?
if you change the gear ratio, you will just be making the engine work harder and you will just lose acceleration at highway speed without getting any better mpg. the guys at honda/ acura have probably figured this out pretty well, just trust them. also a custom transmission would probably be expensive as hell.
about the bearing or dif. i have no idea, sorry
ps i think you mean "drop one in THERE" correct grammar/spelling is pretty loose, use her whenever you want
Old Mar 21, 2011 | 06:46 PM
hondamark35's Avatar
all car companies, designers, engineers and manufactures have to reach some deciding point on the continuum of compromise. there's not a best answer or design to fit every need or situation. all that to say.. you're right! the team that picked the gearing in the F23 transmission paired it well for highway cruising without sacrificing too much "around town." OP: 5th gear is already overdrive... i don't suspect you'll find any more margin for improvement there. less than 3k rpm at 70 mph.. right? you drop out of the "efficiency sweet-spot" below that. and your second question: if you have the technical skill and tools to do the work yourself, no question a rebuild is better. otherwise source a used one. they are not prone to failure in the hands of a competent self-shifter so you should have plenty to chose from and you can use any F-series or H-series box you prefer.
Old Mar 22, 2011 | 09:58 AM
matix246's Avatar
IM pretty sure it a bearing, it has no problems shifting, and as long as i give it gas its fine, only when its on deacceleration is when it makes a noise. at first thought it was the axles but its not. new problem is when i turn it clinks, sorta like a axle would but a little more harsher. Ive looked a little, 1200 rebuild. much cheaper if i pull the trany my self, but i dont really have time for that. ive found a used trany for 350 but again id have to do all the work. so i dunno.
thanks so much for the feed back guys
Old Mar 22, 2011 | 01:01 PM
Originally Posted by HonBeer
High school dropouts tend to have bad grammar.
your posts tend to have little insight or value. please try to be more helpful.
Old Mar 22, 2011 | 04:35 PM
Originally Posted by hondamark35
you're posts tend to have little insight or value. please try to be more helpful.
svtford4x4
Transmission & Drivetrain
68
May 26, 2014 05:48 PM
The Quaff
Dec 19, 2013 05:43 PM
Brybe
Jun 11, 2010 11:02 AM
kornerk12
Mar 12, 2007 02:13 PM
