94 del sol - low end power issue
Old Mar 21, 2011 | 03:30 PM
Jdcamaros's Avatar
Default 94 del sol - low end power issue
I have a 94 del sol vtec that has full exhaust. Edealbrock jg intake. I'm having low end power issues. It won't get out of its own way before vtec. Any ideas?
Old Mar 21, 2011 | 03:36 PM
grumblemarc's Avatar
The Grumpiest
Default Re: no power
D-series? Why the Edelbrock?
Old Mar 22, 2011 | 01:22 AM
Jdcamaros's Avatar
Na its the vtec model it has b16a3 and I bought the car wit that intake already installed.
Old Mar 22, 2011 | 04:38 AM
The Grumpiest
Not a lot of info to go off of. Are you bogging? Sputtering? Hesitation? Or is it not as fast you you think it should be? Did you test drive it prior to buying? What did the previous owner say about it? Last tune up?
Old Mar 22, 2011 | 08:34 AM
Jdcamaros's Avatar
I got it off a buddy who thinks he knows a lot about cars but he don't so information from him is useless. But I just did full tune up. Oil change. Both motor and trans. It I guess kinda bogs but not really it just takes forever to get threw lower rpms. It got worse when I took stock header off and put a dc header on... I think wot the intake and full exhaust. On stock motor. No cams or injectors. It's to much flow and the engine can't get push everything that fast. Or the timing is off. As in retarded. But idk Honda are a whole new ball game for me.. my buddy has a stock b18 91 integra and he walks me. Off the line until we get around 60 and I can keep it in vtec threw the shifts. Pretty much it has no power till third....
Old Mar 27, 2011 | 03:46 PM
Jdcamaros's Avatar
Anyone?
Old Mar 27, 2011 | 03:54 PM
Former User's Avatar
Default Re: 94 del sol - low end power issue
CEL codes? Have you checked the ignition timing with a timing gun?
Old Apr 14, 2011 | 09:20 PM
Jdcamaros's Avatar
No lights right now but I don't really beat on it but one time I did I shifted at red line witch is 8000 and it threw light and would not go above 3500 rpm till I shut car off and back on . Buddy who had it before me told me knock sensor is bad. But idk . I don't have a obd1 scanner. And no I didn't check timing Wat marks and I looking at I'm useto American cars.
Old Apr 14, 2011 | 09:31 PM
You don't need a scanner, just paperclip or piece of wire. Click on the CEL sticky at the top.
Old Apr 15, 2011 | 02:00 AM
Texas4door's Avatar
Sounds like the timing is retarded OR (just found this out through dumb luck) your spark plug gaps could be off, causing it to have less power than it should
Old Apr 15, 2011 | 07:53 AM
Red_Army's Avatar
your redline should be 8200. and if it went into limp mode just from running it to redline in one of the most high rev loving engines i'd worry.
Old Apr 15, 2011 | 08:19 PM
Jdcamaros's Avatar
this will be the same for dohc motor?
Old Apr 15, 2011 | 08:22 PM
Jdcamaros's Avatar
It might be like I said I don't take it that high really I Normaly shift at 6500 7000 when I'm messing around I don't beat on it really. And would a bad knock sensor do that?
Old Apr 16, 2011 | 06:32 AM
visormurp's Avatar
When you said that your friend had a stock integra that beats you down low makes me think your problem might be the size of your exhaust is too big to create enough backpressure to get you moving in the lower rpm range.
Honda really does a pretty good job of matching engine size and exhaust to maximize performance. Typically, when you start increasing the size of the exhaust without supercharging or turbo, low-end performance suffers. You never gave any information about the "full exhaust" so it's a little difficult to say for sure.
Old Apr 16, 2011 | 08:25 AM
Red_Army's Avatar
it might. i've never had to deal with knock sensors much. but i'd imagine if it was faulty the ECU would see it and not want to rock in vtec at 8 grand. try replacing it with a working one. and see what happens.
...no no and backpressure no.
if that were true the 3" exhaust setup would be wrong. and dyno's and track times say otherwise. some even on STOCK cars.
Old Apr 16, 2011 | 09:46 PM
Jdcamaros's Avatar
The only thing I know on exhaust is that the heade is dc. Idk Wat cat back is it does not say. But now I have yet another problem it revs by its self to 3 grand. I was driving after it rained noticed it was a little jumpy when came to stop it started to rev by its self. Think a simple throttle sensor?
Old Apr 16, 2011 | 11:38 PM
MSP's Avatar
MSP
I agree with this, losing a lot of back pressure due to having to large of an exhaust will cause you to lose low end torque. If your car isnt boosted by rule of thumb exhaust should be between 2.25-2.5". Or you could possibly have an exhaust leak somewhere and just aren't noticing it
deconstruct
Mar 27, 2006 01:35 PM
Turbocharged777
Aug 20, 2004 09:49 PM
93delsolsi
May 9, 2004 05:59 PM
Stoned Sour
Mar 7, 2003 04:09 AM
turbomonkeyexpress
Feb 17, 2003 08:45 PM
