TN - 1994 Acura Integra LS 4 door 5 speed
Old Mar 21, 2011 | 02:53 PM
hybridcivicex's Avatar
Default TN - 1994 Acura Integra LS 4 door 5 speed
SOLD!!!
For sale is my 1994 Acura Integra LS 4 door 5 speed with 230,187 miles. This Integra came from the factory without a sunroof. The car was orignially green, but at some point the previous owner painted the car black. His son bolted on a large spoiler on the trunk (since removed) and painted some of the interior pieces white as well as removed the carpet. The motor spun a bearing, so I replaced it along with new OEM parts. In addition, I started the process of changing the interior to all black.
Let me be upfront and say that this car needs some tlc, but it does have a CLEAN CarFax and all of the options work, including a/c!
Exterior:
Side moldings were removed by the previous owner and black duct tape was taped over the holes.
It does have scratches and dings all over the car.
The passenger side rear (near the door) has a little damage that someone tried to repair.
The hood used to have hood pins.
Integra GSR fat five wheels
Kuhmo Ecsta tires 205/50/15
Interior:
Mostly black interior, if it still has the tan part installed I have the black piece with exception of the headliner and seats.
OEM factory CD player (need to enter the code as it's locked)
No speakers
Knockoff Integra Type R shift ****
Mint OEM black carpet with plastic attachment pieces
Engine / Transmission:
Newer replaced LS motor (also from a 94 Integra)
OEM timing belt
OEM timing belt tensioner
OEM timing belt tensioner bolt
OEM water pump
OEM valve cover gasket
OEM spark plug o-ring gaskets
OEM fuel filter
OEM intake manifold gasket
OEM thermostat
OEM distributor cap
OEM distributor rotor
OEM distributor o-ring seal
OEM spark plug wires
NGK ZFR5-11 plugs
Skunk2 cam seal
Skunk2 magnetic oil and transmission drain plugs
Energy Suspension engine mount inserts
Energy Suspension shifter bushings
The car is located in Knoxville and the price is $2,000.00. Please pm me if you have any more questions, thank you.
Old Mar 21, 2011 | 03:04 PM
Default Re: TN - 1994 Acura Integra LS 4 door 5 speed
Engine shot
Old Mar 25, 2011 | 07:59 AM
Pm's returned and it's FRIDAY!
Old Mar 28, 2011 | 05:25 AM
monday
Old Apr 2, 2011 | 05:02 AM
Old Apr 10, 2011 | 05:05 AM
Price Reduced to $2,000.00
Old Apr 10, 2011 | 09:36 AM
B20BP8R's Avatar
bump
Old Apr 11, 2011 | 03:26 PM
SOLD!!!
MoogieBoogie
May 18, 2011 05:02 PM
HeLLa iLL2ndGen
Northern California (Sales)
May 17, 2011 12:38 PM
hybridcivicex
Apr 11, 2011 03:27 PM
hybridcivicex
Southeast (Sales)
Apr 8, 2010 05:18 AM
hybridcivicex
Apr 8, 2010 05:17 AM
