need help with b18a1 power steering
Ok so I just purchased a 94 gsr, owner blew the motor up and it has a b18a1 swapped into it. weaksauce
It does not have power steering and Im trying to find out how i can go about getting power steering put back into it. I have a b18b1 power steering pump, but that didnt fit on the a1 obviously. Ill post some pics of what i have so far. I have some questions.
1) Is this a b18a1 head? or just a b18b1 valve cover on the head?
2) Has the crank pulley been swapped out?
3) Are these the correct power steering brackets?
4) What power steering pump / brackets / or whatever do i need to get power steering put into it?
Here are the pictures of the motor.
so what do you guys think? is it possible for me to get powersteering in here with the a1 motor?
if im not mistaken that head has pr4-2 stamped on it telling me its an A1 head. ur gonna need a DA power steering pump, resevoir, and brackets. luckily im deleting the power steering from my DA so make an offer if you're interested. oh and the crank pulley looks fine. i dont think its been changed
pulleys the stock one, its an a1 head as stated above just with a b1 valve cover. I believe those are the correct brackets but ill double check mine for you tomorrow. as above said i also have a A1 power steering pump and res ill sell you for a good price cause i deleted my ps and its just sitting in my garage collecting dust so id like to see someone get some use out of it.. shoot me a pm with an offer
InTheZoneAC
Feb 16, 2019 06:16 PM
