My Project DC, Nothing Crazy, Just Clean, Simple, and Functional
Just something I'm Workin on... My 95 Integra, Got her w some mods, Since then Been Doin her, My way.
Mind you Im on a Budget, Im a Single Parent and a server. My Roommate, Cousin, and Myself Rent a Small Shop and Do Our Work on the Side.
I call her Dill.
Day 1
As She Sits Today... Doing a little work. lol
I call her Dill.
Day 1
Right now I'm fixing a lot of BS and Upgrading some too...
Whats Happening Now:
Swappin the B18b for a B20z
UR Single Belt Pulley
Shaving the VC
ACT 6puck Clutch w/ PP
ARP Clutch Plate Bolts
OEM Honda TOB
Replacement Steering Rack (Doin a Power Steering Loop)
New Tie Rod Ends
New Axles
B&M Race Shifter
Stainless Braided Clutch Line
1/2 Size Dual Core Radiator
12" Slim Fan
GSR Throttle Body
and
Install My New Front Tires now that ill have my Steering Rack all Fixed. (back are already Mounted)
? Ummm... Functional = Nothing over the Top, Clean and Simple where i can walk up and start it and drive it 6hrs or i can go to the track and make a couple nice passes and not be embarrassed w/ a 15 sec 1/4 Mile time or a 10 sec 1/8th.
Shaving the VC
OEM Honda TOB
New Tie Rod Ends
New Axles
B&M Race Shifter
12" Slim Fan
GSR Throttle Body
and
lol @ the asr brace and running a stock 14mm sway bar. Not to mention the beaks bar which does nothing at all except for hang down for people to see. Oooo look at me!
As for the beaks, thanks for noticing. lol, came on the car when i traded for it, so i got it for FREE, So its cool w/ me!
Primer-ed Green
Got a little work done, Cleaned up the crossmember up from the old busted axles, picking up new Pass. and Driver axles tomorrow. Took off the Clutch pedal hard lines, and Power-steering hard lines.
Got my Radiator Mounted:Moved my Bottom mount over and welded it up & Modded a top mount bracket. Threw my Slim fan on. (Just Test Fitting in pics)
Swapped out my Bad Tie Rod ends (inner and outter) and Installed my Power Steering Loop. (Im Running a Single Belt UR pulley so there wont be any power steering or A/C.)
All with a little help from Snoop
I put the front suspension All together so i can scrub down the Bay and wash out the bay real well before the motor and trans go backin.
Gotta install the shifter, Get my new axles, Fill the Fluids and She should be ready to crank up... I hope!
Side Note: I am gonna grab some NON-ABS lines and do an ABS Delete before long. but my Bay Paint and Shave wont be in the works till i finish my body.
Loving everything about this thing man! Very clean car, side moldings look proper too.
What kind of exhaust btw?
lol, I have a Mildly Built GSR Head, New Honda HG, oil feed line, Arp Rod Bolts and Arp head studs all sitting in the "Closet".... Gonna Re-Build my B18b Block and Drop my head on it later this year.
Got a little more work done. I've been working double shifts everyday since sat. Started having tq mount issues so i called it a night. But i did get the bay all cleaned up, main 3x mounts are on. Gotta a couple little things to do still.
Found out yesterday that Autozone Cant get the Female D.side Axle for my 1/2 Shaft, Due to the warehouse... So now i gotta figure out what to do for my D.side axle...
Are 93 GSR abs axles the same as 94 abs axles?
Finished my Swap for the most part... still needs a little work.
I:
Swapped In My B20z
Threw on a UR Single Belt Pulley
Shaved the VC and painted it
ARP Pressure Plate Bolts
OEM Honda TOB
Replaced my Tie Rod ends (inner and outer)
Power Steering Loop
New Axles
B&M Race Shifter
12" Slim Fan
Mind you this is my "For Now Motor Set up", lol. I'm working on rebuilding my LS/Vtec.
I:
Swapped In My B20z
OEM Honda TOB
Power Steering Loop
New Axles
B&M Race Shifter
12" Slim Fan
color match the moldings, it will be dope. love it, but is the car going to be that low when you plan on traveling 6+ hours? my em1 was similar and took it that far before, on the highway is fine, but if you end up on shitty roads then it gets annoying very fast.
The car is going back to Black when i finish the body. Jams and Bay are all still stock black. She is actually Primmered right now. lol. I'm thinkin about shaving the trim off too.
As far as Driving, Yup, I've driven it on road trips to Nashville and Paducah ky plenty of times. HWY 40 SUCKS going to Nashville...
Keep the build going; I just want to encourage you & I'm locked in to your updates. I think your display pic is so cute with the baby....lol. Keep it going!
