Newbie Question
Old Mar 21, 2011 | 10:32 AM
Pure Sol's Avatar
Default Newbie Question
Just got a Harbor Frieght wire feed from a friend. Not planning on doing anything too serious just maybe filling a couple holes and tacking a couple things together. My question is what wire should I be going with considering I will be working on primarily thin metal? Usually 16 gauge or less. I've done some reading and seems like there are all sorts of wire out there, flux-core, wire-core, stainless, .023-.045 the list goes on. Just a standard gas-less wire feed from HF. Any input would be helpful.
Old Mar 21, 2011 | 11:41 AM
FabChild's Avatar
Default Re: Newbie Question
0.23 Solid Wire Er70s-2,3,or 6 with 75% Argon/25% Co2 will work good for what you want to do.
Old Mar 21, 2011 | 12:13 PM
Pure Sol's Avatar
wow...awesome! Quite the technical answer...same size for the tip I assume?
Old Mar 21, 2011 | 04:24 PM
FabChild's Avatar
Yes, the contact tip must be the same size as the wire.
91ed9
Welding / Fabrication
20
Dec 15, 2007 11:59 AM
HT Chaplain
Aug 1, 2007 12:35 PM
rsdriver17
Mar 10, 2007 09:59 PM
drewzilla
13
Aug 25, 2006 05:10 PM
