Civic Wont Start
I have a 89 Civic sedan that wont start.
When you put the key in the ignition none of the lights come on or anything.
Ive Checked power and continuity to all the fuse boxes and they all have power
The engine is a mini me swap from a 93 civic non vtec
PLEASE HELP
PLEASE HELP
Check all grounds under the hood. my rex did that all the time for the first month i owned it and i was carrying a sub wire around to ground her to start it. then i changed out all the grounds with fresh wire and it hasnt happend since.
do you have power at all? ie; dome light, brake lights, head lights work? if yes. check, as stated already, your thermostat ground. if that is on, check to see if ecu is ground (if youre still obd0). if youre good there, check your ignition switch in your column (as stated by Projekt_Ef9) if that is good. start shooting wires.
kyler253
13
Oct 24, 2012 03:50 PM
civic_angel
May 22, 2007 12:56 PM
