Leaking oil like crazy
Old Mar 21, 2011 | 09:43 AM
Honda_Si21's Avatar
Default Leaking oil like crazy
I've been driving the car for a little over a week, everything was working fine.
Friday night, I decided to act dumb, and I was running my car hard (why lie?) not crazy hard, I kept it at around 4500-5000 rpms. Saturday morning. Drove for donuts, everything good. Later in the day, I was driving to get lunch, and noticed it smelt like something was burning. Pulling into a parking lit, dipped into a manhole and scraped the bottom of my car. Go intonthe store for like 5 minutes and when I came out it seemed like all my oil was flowing across the lot. I assumed I bottomed out and cracked the omil pan but i checked later ant the leak seems to be coming from higher up. Checked if the oil filter was loose but no go. Have no idea what's wrong
P.s. Motor runs fine when I put oil and start it up
Old Mar 21, 2011 | 09:50 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Leaking oil like crazy
Sounds like you blew a seal. Don't drive it again until you make sure what it is.
Old Mar 21, 2011 | 09:57 AM
Honda_Si21's Avatar
I haven't. I'm just tripping kuz I'm worried I blew a piston or cracked my block
The Grumpiest
I'd check the seals first.
Old Mar 21, 2011 | 09:58 AM
pityocamptes's Avatar
Can you see where it is leaking from?
Old Mar 21, 2011 | 10:00 AM
Honda_Si21's Avatar
Ok. Thanks
Old Mar 21, 2011 | 10:02 AM
nucman95's Avatar
Does you engine have VTEC? If so there are two o-rings on the unit that may have cracked. Look to see if oil is coming out above the thermostat on back of the head.
Old Mar 21, 2011 | 10:07 AM
Honda_Si21's Avatar
Pityocamptes- not exactly. I know its around where the oil filter is, maybe higher
Nuncman- no it's a tegra ls engine.
Old Mar 21, 2011 | 10:08 AM
The Grumpiest
Did you hit the pothole THAT hard?
Old Mar 21, 2011 | 10:09 AM
Are you sure its above the filter? Oil leaks can be sneaky and wind their way around parts. How about taking some pics, or at least safely jacking your vehicle up and taking a look with a good flashlight.
Old Mar 21, 2011 | 10:11 AM
Sounds like my sig other after she F*cked up the rims while putting lip stick on...
Old Mar 21, 2011 | 10:20 AM
Honda_Si21's Avatar
Not THAT hard haha. I had just turned into the lot so I was going like 10 mph at the most
I'm at skill right now but later today I'll try and take some pike for you guys. Most of the leaked oil is around that area tho (under and around the filter)
Old Mar 27, 2011 | 08:40 PM
Honda_Si21's Avatar
thanks guys. oil filter seal was cracked. fixed and ready to go haha
ringgold
Sep 17, 2006 10:51 AM
AntMan401
Aug 23, 2006 09:38 AM
redlude97
Jun 24, 2005 06:01 PM
StreetEG
10
Jun 2, 2005 08:55 PM
GsrSdn
Sep 22, 2002 01:10 PM
