Turbo kit,M&W pro 14, built motor, twin disk, ka24de
Old Mar 21, 2011 | 07:32 AM
R@mon's Avatar
Default Turbo kit,M&W pro 14, built motor, twin disk, ka24de
I will update this post with pics as I remove parts from the car.
Complete Long block without manifolds $2850 Includes the following :
700+ whp tested and proven motor
Ka24de
Wiseco Pistons 89.5MM bore w/upgraded wrist pins 9:1 compression
Pauter Rods
Cometic Headgasket
11mm L19 headstuds
ARP main Studs
ATI Crank damper
Shimmed oil pump regulator
Cometic MLS headgasket
BC Stage 3 Cams
BC Springs and Retainers
Balanced rotating assembly
Starter
Alternator
CAS w/ 24 tooth aem trigger wheel
Custom Solid motor mounts
Custom Intake Manifold for 8 injector setup $1350 Includes:
Two fuel rails powder coated black w/ -6AN in and out fittings
Billet 80mm Throttle body w/nissan TPS already mounted.
Turbo Kit $3000 Includes:
Custom Long Runner stainless Steel T4 Divided Manifold
2 x Tial 44mm wastegates
2 x Stainless Steel Dumptubes
Borg Warner S372R Turbo with Race Cover and 1.25AR rear housing
Tial Q BOV welded onto compressor cover
4" Stainless Steel Downpipe
Custom Turbo Hanger with Heim Joint
Hotshot Performance Coatings Inc, Coated Manifold/turbine housing/dumptubes
KA to VG transmission Adapter $1100 Includes:
300zx transmission with bellhousing already machined down
Complete Mazworx trans adapter kit w/ aluminum driveshaft/shifter bracket/short shifter/tranny mount
Competition Clutch Twin Disk clutch w/ Alum Flywheel $750
M&W Pro 14 Ignition Setup With 4 CBR coils and Pre-made Harness $850
R@mon
Mar 21, 2011 02:25 PM
90crxdriver
Dec 5, 2008 11:15 AM
delslowh23
Sep 5, 2007 07:45 AM
BoredNStroked
Northwest (Sales)
11
Apr 17, 2007 01:46 AM
