Honda CR-V & Element 2WD & 4WD Element & CR-V
would someone help me locate the starter on '03 element?
Old Mar 21, 2011 | 07:01 AM
u4ikstilz's Avatar
Icon2 would someone help me locate the starter on '03 element?
car is not starting. tried jump starting and it didn't work. removed power cable from the battery and still no good. the last time that this happened (on a different car) someone came and tapped the starter with a hammer. now i'm tryin to do the same, but i can't locate what exactly is the starter. TIA !
Old Mar 21, 2011 | 12:36 PM
turbodcivic510's Avatar
Default Re: would someone help me locate the starter on '03 element?
If i remember correctly the starter is located on the front side of the engine just below the throttle body.
Old Mar 22, 2011 | 11:55 PM
civicsir924's Avatar
Yeah its under the intake manifold. They take a little bit to get out but not to bad.
Old Mar 23, 2011 | 10:44 AM
Darth Raider's Avatar
They are definitely not located in a real convenient spot, but as civicsir924 said, it does take a little bit to get one out. The starter is located bottom rear of the engine. Just follow positive battery cable, it leads you straight to it.
Chief
Old Mar 28, 2011 | 05:25 AM
saleensolution's Avatar
It's on the front ofbthe engine under the intake manifold. The manifold is two pieces and has reusable gaskets. But do yourself a favor and get a Honda starter. All of the aftermarket starters I've installed had never worked and then u have wasted a bunch of time and money putting on something that doesn't work
jimmy winn
Jan 26, 2015 07:57 PM
Adam1479
Jun 30, 2014 11:13 AM
Yuleluder
Mar 8, 2008 02:44 PM
1fastdc2
Jan 6, 2004 12:20 AM
l
Jul 31, 2002 04:37 PM
