k24/k20 turbo da build
Old Mar 21, 2011 | 05:32 AM
khr-built's Avatar
Default k24/k20 turbo da build
this is as far as i have got with it what do u guys think
Old Mar 21, 2011 | 06:42 AM
MantisX's Avatar
Default Re: k24/k20 turbo da build
Mind blown.
Old Mar 21, 2011 | 09:37 AM
sirmugenpower's Avatar
sick
Old Mar 21, 2011 | 12:28 PM
d3viant's Avatar
in for the build.
Old Mar 21, 2011 | 06:21 PM
khr-built's Avatar
thanks guy
dose anyone know of a hydro conv kit without the cable lol?
Old Mar 21, 2011 | 07:44 PM
hondalover91crx's Avatar
Requires a reversed underdash master cylinder or you may be able to use a pulltype wilwood mastercylinder, or adapt eg pedal assembly and modify firewall not much room eitherway
Old Mar 21, 2011 | 07:56 PM
khr-built's Avatar
cool thanks man
Old Mar 21, 2011 | 08:31 PM
khr-built's Avatar
a1
some more pics
Old Mar 22, 2011 | 06:53 AM
CDecker0218's Avatar
A+ thread right here. Infor this build! what turbo are you running?
Old Mar 22, 2011 | 06:17 PM
khr-built's Avatar
its a 58 hotside 70 coldside t4 but iam looking into a new Percision
Old Mar 22, 2011 | 09:41 PM
OhMy-EK9's Avatar
keep up the good work
Old Mar 23, 2011 | 10:57 AM
javiDC4's Avatar
that looks mean!!!
Old Mar 24, 2011 | 05:11 AM
khr-built's Avatar
Originally Posted by javiDC4
that looks mean!!!
thanks
Old Mar 24, 2011 | 12:41 PM
hush22's Avatar
its gonna be sick!! not very many DA's roll that hard!
Old Mar 25, 2011 | 05:57 AM
khr-built's Avatar
and that is y i did a da lol
Old Mar 25, 2011 | 10:45 AM
eg-perk's Avatar
any info on the motor?
Old Mar 25, 2011 | 11:21 AM
GREGBCISCRX's Avatar
MY BROTHER IS GOING TO BE SO JEALOUS
Old Mar 25, 2011 | 03:49 PM
k20rex's Avatar
Originally Posted by khr-built
thanks guy
nice build, suja 1 sell hydro clutch kits
Old Mar 25, 2011 | 06:30 PM
khr-built's Avatar
it a k24a1 je 10.1 comp pistons,manley rods with a ported k20a2 head with
skunk 2 springs and Retainers stock cams that about it lol
Old Mar 25, 2011 | 06:32 PM
khr-built's Avatar
thanks,i just got one from hush22 they make a nice kit
Old Mar 27, 2011 | 08:58 PM
khr-built's Avatar
if anyone has a 40r turbo for sale let me know lol
Old Mar 30, 2011 | 12:23 PM
hush22's Avatar
Thank you BRO. The part here pictured is the display model which is why its a little scratched.
Pictured here is the bracket mounted to the DA pedal assembly
Old May 8, 2011 | 06:14 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
^^edit: how much are those? do they work well?
mind blown x2...
you should seriously, seriously consider stitch welding your chassis. if anybody n
NEEDS it done, it's you. just a k24 in itself, with adding that kind of torque... aaand then throw a turbo on, too?
yea. I'd start grinding the paint away from the sheet metal seams, and start stitching. pull the windshield, spot weld around it, etc. it will make your car not feel like a shoebox deathtrap rollerskate (as much lol). you will be able to keep more torque down. it will handle much better, etc...
Old May 12, 2011 | 11:34 AM
hush22's Avatar
Just like our EF conversions, the DA conversion bolts directly to the DA pedal assembly and requires no welding or extra fabrication to assemble. It locates the clutch master in under the dash board for a clean tuck look. depending on the pressure plate used the pedal pressure is that of stock feel.
Old May 12, 2011 | 02:28 PM
NebuR's Avatar
sick build
