hay 91 accord idles up and down
Old Mar 20, 2011 | 11:25 PM
killerkali420's Avatar
Default hay 91 accord idles up and down
i have a 91 honda accord ex that idles up and down butwhen i take the # 21 vaccume line off it stops. can anyone tell me whats going on with my car
Old Mar 21, 2011 | 04:21 AM
nus_dogg's Avatar
Default Re: hay 91 accord idles up and down
When does it do it? When it's cold or running hot at nomral temp?
Old Mar 21, 2011 | 02:54 PM
all the time dosent matter on the temp
Old Mar 21, 2011 | 08:24 PM
matrix9_11's Avatar
tighten the idle air valvle scew up i had two different ones do the same thing and another one was the intake gasket it sounds the same
Old Mar 22, 2011 | 07:18 AM
MC Slide Hammer's Avatar
apparently, idle surging happens with any vacuum leak.
i once had to unbolt my egr valve and had to leave it on loose; i started and ran the car - it was surging.
it just so happens that the fast idle thermal valve tends to be the most common (naturally occurring, when cold) source of a leak on hondas, though that may not be the case here.
try to find out what the source of your vacuum leak is -what is vacumm line 21 hooked up to?- and fix it.
BuiltF22
Jul 25, 2015 09:04 PM
desertratt
Sep 15, 2011 11:35 PM
F22_CB7
Jan 5, 2009 12:21 PM
ED6JDM
Jan 21, 2007 12:19 PM
mean_1
Jul 30, 2004 06:30 PM
