Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Re:less than an inch drop. do i need a camber correction ?
Old Mar 20, 2011 | 10:37 PM
zapote's Avatar
Default Re:less than an inch drop. do i need a camber correction ?
Hi Guys,
I'm new here and i just joined and i dont know if i am on the right spot.anyway, i have a question. I am getting an H&R OE sport spring and i really wanted to lower my car at least less than an inch drop and H&R OE is the only spring that has at least .75 drop. i dont want to lower my car more than an inch. my question is,do i need a camber correction kit for this low? i know i still need to allign my car but do i really need the camber kit? i've read a lot some people say i dont need it if it's lower than an inch,some people say i have to. can you guys clear my mind on this one. Thanks a lot and i will really appreciate any help.
BTW, I have 08' Civic Coupe.
Old Mar 20, 2011 | 10:59 PM
Darken0420's Avatar
Default Re: less than an inch drop. do i need a camber correction ?
Not to sound rude but why spend the money to drop the car at all? If you don't want it dropped that much than just don't do it. Just a waste of money in my eyes...
To answer your question, If you rotate you wheels alot the small drop should not make much difference. If anything it will give you a little more grip in the twistys.
Old Mar 21, 2011 | 04:57 AM
na+b18c_hatch's Avatar
you should be fine with just an alignment
Old Mar 21, 2011 | 08:47 AM
T3KNiQe's Avatar
Negative
Old Mar 21, 2011 | 09:06 AM
PreyStayShun's Avatar
No, you will not need a camber kit unless your running into the 1.5"+ range...
PS- Good spring choice, don't listen to Darken0420. To each their own right? The H&R OE sports are better then your OEM springs, my friend has them on his SI and they're tastefully perfect.
bb6kid
Apr 15, 2007 05:50 PM
bja2704
Jan 17, 2006 07:13 PM
AgentJam
Sep 11, 2003 06:09 AM
out2wincrx
17
Jul 31, 2002 03:42 AM
StinkyTofu
Jul 25, 2001 12:07 AM
