94 accord broken distributor bolts HELP!
Old Mar 20, 2011 | 05:37 PM
portugueboy10's Avatar
Post 94 accord broken distributor bolts HELP!
ok so i jus bought a 94 accord ex 2.2 with vtec and i was changing the distributor cap and all the bolts snaped, can anyone help me on what to do
Old Mar 20, 2011 | 05:46 PM
nus_dogg's Avatar
Default Re: 94 accord broken distributor bolts HELP!
Damn, which way did you turn the screws? Lefty or Righty?? They don't just snap if you loosen them right.
Old Mar 20, 2011 | 05:49 PM
lol i kno but i was loosening them and all the jus snapped
Old Mar 20, 2011 | 05:51 PM
accordmatt's Avatar
a few ways it depends how they broke. if there tightand the end of screw is hanging out back u could vise-grip it out rest of way. or easy-out drill bit or a drill bit about the same size but smaller to miss threads if u have a steady hand
Old Mar 20, 2011 | 06:03 PM
yeah i tried the drillin part but didnt work very well ill try the vice grips thanks
Old Mar 20, 2011 | 06:07 PM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
Take out the dist. that'll make things easier or is it off the car?
Old Mar 20, 2011 | 07:20 PM
na its still on the car im worried those bolts are gonna break also
Old Mar 20, 2011 | 07:32 PM
Havasu_Junkie's Avatar
Those 3 12mm bolts that hold the distributor on will not break. Take them out, remove the distributor from the car, try to vice grip the cap bolts out from the back side flange, heat them up with a propane torch if you have one. Those bolts are pretty common for breaking, if you cant get them out or you screw up the distributor you will need to get one from a junk yard or a new one. Good luck.
PatrickGSR94
Aug 16, 2016 12:31 PM
76 camaro car
May 15, 2011 07:30 PM
kitt
Apr 23, 2010 11:08 PM
wizardman
Aug 28, 2007 04:10 AM
T-Mo
Sep 27, 2003 12:36 PM
