Suspension & Brakes Theory, alignment, spring rates....
lost coilover tool where to buy one?
Old Mar 20, 2011 | 03:49 PM
matpl500's Avatar
Default lost coilover tool where to buy one?
Where can i buy a universal one? The guywho sold it to me kept the key with him and i cant get into contact with him and this dumbass lowered the back but left the front stock -_-. if anything guys please let me know thanks.
Old Mar 20, 2011 | 04:49 PM
PreyStayShun's Avatar
Default Re: lost coilover tool where to buy one?
They're not necessarily "universal" to my knowledge.
Do you know what kind of coilovers you have by chance? If I'm incorrect (open ears here) I know Tein sells them for $20 or so.
Also, a good thing to do is go to your local import shop...typically they tend to acquire different coilover keys w/due time so they may be able to help. Although I'm sure they'll charge a buck or two. Just an idea...
batallic's Avatar
there isnt really a universal tool, u can try using a hammer and a screwdriver, or post a pic of them so we can help identify it for u
Old Mar 21, 2011 | 07:35 AM
lunareg's Avatar
^this
it works just fine if you have no tool, almost just as much of a pain in the *** as using the actual tool.
Old Mar 21, 2011 | 07:39 AM
siblues's Avatar
they are sometimes sold as spanner wrenches and sell for anywhere from 5-30 dollars a piece.
Old Mar 21, 2011 | 10:18 AM
Andy@AMR's Avatar
We are out of them right now. The company that water jets them for us is really backed up. I should have some in a few weeks.
We sell a universal spanner wrench that works with most aftermarket coilovers.
Old Mar 21, 2011 | 10:25 AM
gabebauman's Avatar
Originally Posted by gabebauman
I've heard that using two of these rubber strap wrenches works.
They're fairly cheap...and I use mine to loosen my oil filter.
Old Mar 21, 2011 | 06:35 PM
matpl500's Avatar
thanks for all the responses guys i will be trying the screwdriver and hammer tool this weekend and ill let you guys know hw it goes.
Old Mar 25, 2011 | 06:42 AM
matpl500's Avatar
i forgot to ask guys sorry, but when adjusting the suspension the wheels will be off so how do i measure so everything is equally balanced?
Old Mar 25, 2011 | 07:47 AM
lunareg's Avatar
its alot of trial and error honestly. What I do is measure from the center of the axle nut to the middle of the fender with both wheels in the air and then lower them and make sure both sides are the same. but this wont really tell you how far youve gone until you put the car back on the ground. Then I measure from the center of the fender to the ground (on a level surface) to make sure all the sides are the same.
I hate adjusting coilovers...
Old Mar 25, 2011 | 05:02 PM
TunerN00b's Avatar
Since you wrote "balanced", the answer is "with 4 scales".
Or did you want the car level instead? If so, make an initial guess, set the car down without fully tightening any of the bolts a suspension arm moves on (don't want to clock the bushings incorrectly), adjust height as needed, then properly clock the bushings and call it done.
laxer1991
Suspension & Brakes
Feb 26, 2011 05:29 PM
GSR Apollo
Feb 22, 2009 04:34 PM
DA BOSS
Southwest
Sep 13, 2008 03:41 PM
jdm[boy].ek4
Suspension & Brakes
Jan 7, 2008 05:15 PM
