"miss civic" 95 hatch - built turbo d16 with a side of giggle juice
Old Mar 20, 2011 | 12:13 PM
scottdh20's Avatar
Default "miss civic" 95 hatch - built turbo d16 with a side of giggle juice
sorry if some of this doesnt make sence copied and pasted from antother forum
so i thought i would start a new project log as my build has gone in a very different direction...
for those that dont know the back story ...i never finished updating it, but got it all together and spun a bearing on the way home from getting tuned....here is the old project log:
https://honda-tech.com/forums/showth...2559335&page=4
the name "miss civic" was given to my car by my g/f ..... she claims i'm having an affair with miss civic and she is just going to have to learn to live with the fact i got two ladies in my life that need constant attention and money
anyways i will start from just a few months back to get you up to speed
last year for the few weeks it actually lived before spinning a bearing
and now....block and arp's are in, head and turbokit are just sitting as i was test fitting the new intercooler pipes
current mod list:
engine:
-block
built d16y7 (eagle rods/std bore vitara)
arp head studs
dual core radiator
slim fan w/shroud
-head (z6)
skunk2 valves
crower valve springs
272-2(bisi 2.4 clone) delta cam
milled
port and polish w/ gasket match
Cleaned up bowls
Back cut valves
Competionion 3 angle (5 angle) valve job
deshrouded valves
aem cam gear
3" exhaust
edlebrock performer-x mani
skunk2 70mm throttle body
spoon oil cap
turbo:
8 blade hx35
forward facing twin-scroll manifold
x2 mini external ebay wastegate 16psi springs
3" v-band down pipe
2.5 ic pipes....had them all bead rolled
genuine blitz blow off valve
godspeed fmic
rc 750cc sat. injectors
walbro 255
stealthmode oil line kit
tuner toys block fitting
ngk- bkr7e @ .20 gap
nrg catch can
nitrous:
nos brand sniper kit
comes with 35/50/75 jets....as of now most likely going w/ 50 shot
*SOLD OFF THE KIT.....
drivetrain:
egay short shifter (over 4years now )
3" shifter extension
new f1 stage 3 sprung 6 puck clutch and performance pressure plate...im hoping it'll last for the rest of the season....i bought it with 280-300whp in mind....
si 5-speed
rollers;
street - 16" dr-16 with toyo tires
track- 24.5x8x14 mickey tompson drag slicks screwed onto some hx's
suspention:
k-sport coilovers
generic red rlca's
exterior:
spoon style front lip
ek sideskirts
amber corners
50/50 tail lights
spoon style mirrors
carbon fiber duckbill
vis vented carbon hood
rain gaurd things on the windows
diy black housing headlights
alot of stickers like a ricer
interior:
knock off red recaros, will get upgraded eventually
4 point harness
autopower 4 point cage
clock
jdm center audio consol
aem uego wideband
carbon fiber radio block off plate w/ autometer boost and oil pressure gauges
carbon fiber gauge cluster shroud
rear strut bar
itr shift ****
armrest
full black interior swap all the way down to the cargo cover
v3 dvd/cd player
5 1/4 pioneer door speakers
pioneer immp 12"sub
generic 450watt amp(250rms)
tuned by me on crome pro @ 22psi ....
the plan is next season to have the tune done by RCautoworks at 25-30psi
down the road will be better suspension and paint
goals are 11.999 or faster and 400+whp
Old Mar 20, 2011 | 12:14 PM
scottdh20's Avatar
Default Re: "miss civic" 95 hatch - built turbo d16 with a side of giggle juice
Delta 272-2 :D
scottdh20's Avatar
dont forget the turbo is not the only power adder......it will also have a 50 shot....and i have access to a fairly cheap hx35 and i already bought a t3 log mani if its not enough
small update...picked it up this earlier
and i told them to leave the ports a little ruff for better atomazation of the fuel....but is this to ruff
Old Mar 20, 2011 | 12:16 PM
scottdh20's Avatar
brought it back and they were pissed at the guy who did the porting...he went home sick early and bagged up my head....they assumed it was done since it was bagged on the cart....they finished it up for me
Old Mar 20, 2011 | 12:17 PM
scottdh20's Avatar
well got a little done since its starting to warm up....it was 42* today yaaaaa....thursday im going to get a bit more done aswell....its supposed to be upper 50's.....finally
- head torqued to 65ft/lbs
- turbo/mani/wastegate bolted up
- intake mani/chargepipes juat sitting there for fitment and to mock up bov placement
- old harness removed, i have to solder up a couple wires on the chassis harness before i can put in the new si harness
-tried to figure out where to put the catch can.......still trying to figure that out
- radiator installed
pics for the ******
woot woot for tomorrow's delivery....
Old Mar 20, 2011 | 12:18 PM
scottdh20's Avatar
nos brand sniper kit....comes with 35,50,75 jets ..... as of now im planning on the 50 shot.
per all the nissan guys, the snail is going to top out at 18psi......i plan on maybe 16-18psi on the street...as high as safely possible really
for the track maybe toss 20-22psi at it with the 50 shot...we'll see how it works out
the nitrous should turn that ridiculously hot air intpo something cold, dense and usable that my thinking behind it anyway...that and the nitrous will give me a bit to....
i see most gt28r(30lbs/min) turbos topping out at 280whp or so so my t28(33lbs/min) will hopefully get me to 300whp....and then whatever the nitrous adds on top for the track....set-up better get me to 11.999 or faster
Old Mar 20, 2011 | 05:33 PM
Smokeeey420's Avatar
sick hatch....love the boosted d's.....good luck with ur goals
Old Mar 20, 2011 | 06:16 PM
2000CivicCX's Avatar
this gives me hope for d16y7 haha. good luck. looks cool!
Old Mar 20, 2011 | 07:03 PM
Roadwarrior73's Avatar
I like where its going man.. Subscribed.
Old Mar 21, 2011 | 12:21 PM
scottdh20's Avatar
thanks for the kind words
also here is a pic of the temporary rollers - bbs asa em9's
once the tires are gone i'm going to sell them and drop down to a 15 to run some dunlop star specs since they dont make them in a 205-40(or 45)-16
Old Mar 28, 2011 | 05:58 PM
scottdh20's Avatar
picked up a lil something......just incase i wanna go with the hx35
no its not a cheap ebay mani....but the t3 flange and wastgate flange is cracked.....no biggy, its not anything i cant fix....it has a bmc d16 flange so im guessing someone made it....i dont think bmc actually makes manifolds
and i got a ****-ton done to the car......new harness installed, a few plugs seem to be missing.....i gotta spend some time to figure it out if they are missing or i missed them, i had to swap out water-pipes because apparently the y7 only has one nipple not two....i just about torqued down the mani before i saw that was missing....took awhile but i got it....
mani hooked up and pluged in, same with turbo mani
its getting closer
Old Mar 28, 2011 | 10:34 PM
92bseries's Avatar
jus swap it and ur set
Old Mar 29, 2011 | 03:27 AM
scottdh20's Avatar
swap what?
Old Apr 9, 2011 | 10:40 AM
sh!ft's Avatar
Who the fack changed my title?!
what did you use to mount the gauges?
Old Apr 10, 2011 | 05:38 AM
ken9's Avatar
Could got a LSD trans
Old Apr 12, 2011 | 04:24 AM
scottdh20's Avatar
pm me info
what gauges.....i have a discontinued along *** time ago autometer dash pod and i have the lower jdm audio consol i put my radio in, then made a block off plate with a couple 2" holes cut for the gauges in the radio space
small update:
so i sold my t28/ mani/ downpipe......
and bought an hx35 (8 blade) ....had fiment issues with the gigantic comp housing so i brought my mani to ledger racing which is extremely good at what they do which consists more off rally / baja / offroading vehicles.....they are a complete fab shop with great prices
so ~100 later i got the manifold back from the welder....well that also counts the bov flange welded and bead rolled chargepipes.....
but it came out great....its placed perfect and also has the flange cocked slightly to make the comp housing sit even with the head flange so i will have block clearence as well....unfortunalty the slave cyl. is in the way....nothing an h22 slave wont fix
on to the pics you damn ******
and onto the hx35....from what i've read up on lightly is that is the older style as it has 8 blades on the compressor wheel
im either going to have to have hit redo the wg runner as its to close to the core support or notch the core support.....i'm going to pick up my injectors today(rc 750cc) that i picked up on a local forum as well as stop by o'reileys at lunch and pick up the slave cyl.
shooting for 400+whp /11's this year/ 10's next year with bigger slicks and better suspention..... will have more pics soon
Old Apr 13, 2011 | 05:16 AM
scottdh20's Avatar
its in.....well one bolt...still need a t3 gasket and wg gasket.....i had the little box with all the **** that came w/ the wg and i cannot for the life of me find it that had extra hardware and gaskets....anywho..... pics of mockup
and i had to make a lil extra room
gound out a fair amount of material there and also on the rib behind the turbo....its had to tell but the pic is of one of the bulges from the block where the tranny bolt goes
also finished mocking up the charge pipes, i got the one pipe marked where it needs to be cut and bead rolled, and the 90* coupler that came with the kit had a 2 to 2 1/2" 90 reducer....i need a 2 1/2 90*
-drain line fitting is on its way
-walbro 255 is on its way from greg at go-autoworks
-new 5 bolt aem cam gear is on its way
also thank you tron(xceedspeed and DSO)....i had to hog out the mounting holes on the h22 slave cylinder as they were a bit wider by about 1/4" but all is well.....and with ample clearence now
Old Apr 19, 2011 | 04:37 AM
scottdh20's Avatar
im not very good at updating this
4-14-11
i think these should quench the thirst of the hx35
saturated 750cc rc injectors
also trying to figure out this wiring nightmare.....i dont know what the hell is going on, i bought it from a member on xceedspeed.com and it is rediculus.....ok if wired or plugs break but all you have to do is wire them back up to the same color wire....the vtec plug is wired to the temp sensor wires...the other grey plug that goes to the vtec sol. is running another sensors wire, the plug for the speed sensor is non existent....as so much more....this is the reason i bought a vtec harness....i just wanted a plug and play harness without having to wire **** up....ughhh
this all started cuz the speed sensor and temp sensor plugs were gone....i noticed the o2 sensor was rewired...upon further investigation i see that there is new elec tape....once i pealed it back i wanted to punch someone....no nothing was soldered...not even twisted properly
anyone got a really cheap vtec harness....that is not molested
Old Apr 19, 2011 | 04:38 AM
scottdh20's Avatar
4-15-11
this showed up today.....now i can time the motor and adjust the valve lash this weekend....
Old Apr 19, 2011 | 04:39 AM
scottdh20's Avatar
4-16-11
well i was gonna pick up a spare parts harness from benny...but he forgot it....so...i man'd up and got to work
before:
during:
after:
all soldered, heat shunk, wire loomed and taped up
also got some more goodies in the mail
walbro 255 from my man greg at GOautoworks
and i had to rep my favorite state
ordered and awaiting arival:
ebay 3" downpipe ....honestly cheaper than buying the flanges, flex pipe, mandrel bends, pipe .....already know that is going to need mods...still gotta order the v-band flange
t3 gasket
m16x1.5 to 4an adapter
4an to 3an adapter
90* 2.5-2.5 silicone coupler..... my kit came with a 2"-2.5" 90* reducer
and my drain flange showed up yesterday as well
i also found out that my oil pan does not fit.....so i gotta go to the junkyard and find a y7/y8 oil pan and pick-up
got a ton done today.....aside from the few hours i spent repairing the harness(did i mention he had the injector plugs all f-d up to...yes i fixed those as well) intake mani permently on, 90% complete battery relocation to the rear hatch...gotta go to the wal-marts and get me a marine battery box for $15.00. cleaned up the bay a bit...got a bunch of the small yety time consuming things out the way so when i got to start up its all done
still need
ecu vtec conversion parts
basemap
3" v-band flange and clamp
y-series oil pan and pick up
drain bung for oil pan
TIME!!!!
Old Apr 27, 2011 | 02:59 AM
scottdh20's Avatar
got some small updates
well i got some suspention goodies
i got these some time ago...just never got around to taking pics
also sold the nitrous kit to fund a killer deal on some used k-sports
and a lovely present from my fience
and my 3" dp came in....gotta get a v-band for it
also got some work done today.....went to the local speed shop and they had a 90* 4an to 4an swivle fitting that worked perfect...my feed line did not fit with the fittings i ordered ....so got mani/turbo/ oilfeed/ wastegate all bolted up.....not much but it took a bit of work....had to do some trimming to the underside of the core support to get the mani on. it all fit on mock up bolting on one by one, but getting the entire assembly put together i needed a bit more room to slide it into place.....so onto a couple pics
i keep forgetting to grab the valve cover so i can drill one more hole in it for the breather set-up
Old May 24, 2011 | 03:29 AM
scottdh20's Avatar
been a while.......let me catch you guys up
5/6/11
went a different route on my hot side charge piping....cut a little out of the core support "webbing" whatever you want to call in....and tossed a 90 off the fmic and then a 90 aluminum pipe to the turbo....prolly cut 2 ft of piping out doing it this way as well....main reason is i have a driver side downpipe....this gives me tons of room for it
F*CK SUSPENTION WORK for real....i got the driver side rear just about done...took an hour and a half between broken bolts, cutting, punching, ect to get it all out so i can install ksports and rlca's i have...fronts are already on, one spindle is at the shop getting new wheel bearing and lower ball joint....oh and walbro 255 is installed as well
vc has beed drilled and vented, oil pan i picked up at the junk yard is in the truck and need to bring it to the shop to drill it for the drain fitting, got a battery box and its all wired i just need to permanatly mount the box and im gonna put in a vent tube for it. got all my fluids sitting there.....had the hot side piping i made beadrolled and i installed it...gonna meet up with a guy this weekend sometime so he can convert my p06 to a p28 and i ordered a xeno base map a few days ago so that should be here anytime now....it'll be up and running next week...fingerss crossed
there is a 1/4 to 1/2" gap all the way around that should account for engine movement
and i never heard of borg werner wires but they assured me they were really good quaility....he tried to sell me the cheap ones cuz he was not to keen on special ordering the ngk's....i said well they are going on a 400+whp civic....his eyes opened wide and he goes damn...well then i suggest these....lol
any feedback on these would be nice....are they going to be ok
5/6/11.....later in the day
Also picked up this bad boy from the shop
Driver side spindle + new wheel bearing and lower balljoint...along with the arp extended studs....might look funny for a few weeks till I get around to doing the other side....total for both set of arps,1 wheel bearing and balljoint all installed....130 can't complain about that
5/9/11
got alot done yesterday....she is just about ready to turn over
still need my base map from xenocron ...i think it'll be here today, and i need to get my ecu converted....i was going to a local guy that has all the stuff already but he is next to impossible to get ahold of.....install alt. belt....go back a check every nut and bolt that it is tight.....i also need my other v-band flanges to get here asap....i ordered them friday which sucks....so they should be here sometime this week then i can have the fab dude cut and tack weld the flange on so i can drive to his shop ~ 3 miles and have him get the dp right
once i get it back on all 4's i need to pull it out of the garage to be able to get to the pass. rear and get that suspention swapped out
also got my vband flanges in and vbanded the downpie.....and yes i got all 4 corners done.....i want it lower buti need a break from suspention work for a min....lol
scottdh20's Avatar
5/15/11
well it made it to thwe xceedspeed.com westside meet....
having some oiling problems....
cold start = good oil psi ~85-95psi
warm idle = bad ~ 5-10psi
cruise = low ~ 45psi at 3300rpms in 5th gear highway cruising
builds pressure just fine.... motor is running 5w30
gonna swap out oil for 10w40 or 20w50 and see what happens....i just had this oil lying around and i know i have to change it withing 100miles so we'll see there
temps seemed ok...on the higherside which i figure is the fact the radiator is just about touching the manifold
open 3" downpipe with big cam = load yet very mean sound......lol....needless to say i need an exhaust asap....and to adjust the coilovers lower
phone was dead at the meet but i shot some once i got home
Old Jun 24, 2011 | 06:48 AM
Jrod07's Avatar
Really nice build thread, any updates?
Old Jun 24, 2011 | 07:17 AM
jdmcx's Avatar
nice to see another michigan car getting work
where did you get that decal with the state and glock
