Upper Ball joints are effed. Excuse to buy Adjustables now present. But which ones?
Old Mar 20, 2011 | 10:03 AM
julioboostamante's Avatar
Default Upper Ball joints are effed. Excuse to buy Adjustables now present. But which ones?
I finally decided to swap out the stock Brakes for DA components and upon doing so i find that not only is my Upper A-arm Ball joint has gone bad but the inner tie rod on the passenger side is gone as well. At this point i have an excuse to purchase Upper adjustable ones but Skunk2's are a bit pricey and im not sure i trust the Ebay ones. I'd like some feedback as i did a search and found info dated back further than i'd like.
Thanks guys!
here is what I have found so far
http://cgi.ebay.com/ebaymotors/SKUNK...#ht_2495wt_930
http://cgi.ebay.com/ebaymotors/CIVIC...ht_2643wt_1029
I also see that Revo us to make some but cannot find any info on where they are sold or if they are produced still.
Old Mar 20, 2011 | 10:17 AM
crx_si-r's Avatar
Default Re: Upper Ball joints are effed. Excuse to buy Adjustables now present. But which one
I have my stock UCA if your interested I swapped mine for the skunk2
Old Mar 20, 2011 | 10:20 AM
Originally Posted by crx_si-r
I have my stick UCA if your interested I swapped mine for the skunk2
I appreciate that but since the Sedan is lowered i'd like to get some that are Adjustable. But then again, i guess a simple fix will do as well. Sucks you are up north though as if you were closer i'd come get em right now.
Old Mar 20, 2011 | 10:24 AM
efjones9's Avatar
adjustables are a waste of $$ un less u wana adjust to the negative side. when lowered, the toe is only effected
Old Mar 20, 2011 | 10:38 AM
How is the Camber not affected? I can see the toe being an issue but still, I would imagine that the Camber would need some attention. At this point i think a simple replacement will have to do. The A arms are from a 90-91 civic which i believe make the Ball joint serviceable. If that's true then ill either change it or hit up the junk and grab another.
Old Mar 20, 2011 | 10:39 AM
BiG ChOr!Zo's Avatar
not sure why you want adjustables but i would spend the money on quality replacement upper control arms with ball joints and tie rods from moog...skunk2 isn't even in the same league compared to moog and costs about $60 for the uca's and about $35 for the tie rods...!!!
Old Mar 20, 2011 | 10:41 AM
JustOneOrTwoPosts's Avatar
huge discussion of camber on lowered vehicles in the suspension forum here https://honda-tech.com/forums/suspension-brakes-54/no-you-do-not-need-camber-kits-2614449/
Old Mar 20, 2011 | 10:43 AM
Yeah, the more i think about it i think ill stick to the Stock uppers. There is up and down play on the driver side ball joint at the top and that worries me. I would hate for the ball joint to separate while i'm driving. Any chance that this is possible?
Old Mar 21, 2011 | 08:42 AM
efjones9's Avatar
imo the camber angle is close enough to spec on my car atleast and i have toe problems more than camber issuses
Old Mar 21, 2011 | 03:04 PM
3Rd_gEn_LuDE's Avatar
http://www.robearracing.com/pd-revo-...ccrx-88-91.cfm
I used godspeed camber kit to fix a toe issue i had, been riding it for the pass 4months no probs not bad for 30$ ebay kit :I.
But only since i plan on getting in to autox later on check these out...
http://www.buyhardrace.com/product/h...vic-ef_86.html
black0hatch
Honda CR-V & Element
13
Sep 5, 2012 04:49 AM
invisible
Suspension & Brakes
12
Feb 6, 2007 08:02 AM
herovueboi
Sep 17, 2006 07:30 PM
donut.
11
Oct 17, 2005 12:17 PM
brianbrannon
Jul 30, 2003 07:55 AM
