dohc zc question.
Old Mar 20, 2011 | 07:21 AM
Wingate457's Avatar
Default dohc zc question.
just bought a 1990 civic hatch. motor was with the car but not in it. Owner said it ran fine but he pulled the motor to start building it i guess? So i picked the car up and put the motor in and all. hooked everything up. and its not starting. When the key isnt in the ignition, the check engine light is on and the door chime is going off, just like the key is in and ignition turned on. Motor does crank over when you turn the key though. I assume someone messed up the harness conversion. Is it possible to go to the junkyard and get a like 89 integra harness and ecu and just put that in? Any wires need to be changed? Sorry i searched alot and maybe i just didnt understand how people said it. I am new to hondas.
Old Mar 20, 2011 | 06:37 PM
99_Taco_Supreme's Avatar
Default Re: dohc zc question.
Sorry I can't personally help you out, but I thought I'd give you a bump.
Unfortunately the dohc zc is an underappreciated engine due to the lack of aftermarket parts, so not many people have them. I had one in my first ef though, you could beat on that thing all day long and it ran like a champ!
Hopefully there are a few people here that can help you out. Good luck man.
Old Mar 20, 2011 | 11:53 PM
hatchet_honda's Avatar
that integra harness isnt gonna work on this car
Old Mar 21, 2011 | 06:57 AM
mr.jdmcrxzc's Avatar
what kind of hb dx hx si.....? if its a SI get an SI harness..i just had the same problem with my zc no start so i giggled the wires to the starter and it started to crank but thats all so i reached under the dash by the hood popper and tapd on the fuel relay they go bad after a while and sitting then it sounded like it tryed to fire but timing was off but timing belt is on so idk well any way.... grab a haynes shop book and make sure all your wires are right and solder together (dont use butt connectors) and make sure your grounds r right and heres a biggie if you can get your hands on a pm7 ecu get it its the DOHC ZC ecu and i know RYWIRE.com has wire harness setups for the si to zc swap it was like $30 idk if this helps at all
Old Mar 22, 2011 | 06:20 PM
x2 on getting the correct ecu. I didn't have the dohc zc ecu and i never got the full potential out of the motor. It was still quick though, just not AS quick.
Old Mar 23, 2011 | 06:19 AM
Jockone's Avatar
You need to get an engine harness that matches your chassis.
If its an Si then you either get an adapter harness or change the dizzy plug for Dx and use the 2 extra wires for the ZC cam sensor.
If its a DX or STD then you need to wire it for MPFI.
SodaChimp
Jul 23, 2017 08:18 AM
oldskool88291
19
Jan 14, 2008 11:06 AM
tegracer19
Oct 13, 2007 07:16 PM
SHIFKU(EF9 HOPE FUL)
14
Nov 1, 2005 09:55 AM
