Gas meter stopped reading (dc2)
Old Mar 20, 2011 | 01:35 AM
dc2_build's Avatar
Default Gas meter stopped reading (dc2)
What's up h-t. First of all I have a 96 get with a 99+ usdm itr cluster. I've had the cluster in my car for over a year now and everything worked fine.
Yesterday I pumped like 4 gallons in the tank and I had plenty of gas reading almost a half tank. About an hour later the gas meter was under the E and not moving I tried turning the power off and on but it's still the same. Could my cluster be messed up or maybe something in the gas tank.
I just wanna know if any1 has had a similar problem with a usdm itr cluster or if it's a common problem. Hit me up thanks
Old Mar 23, 2011 | 08:55 PM
EJ1_CRIS_909's Avatar
Default Re: Gas meter stopped reading (dc2)
Try checking the wiring, and im pretty sure there is a sensor around the fuel pump that reads it. Check that too and the wiring.
Old Mar 25, 2011 | 07:52 PM
wayneshondawork's Avatar
the fuel pump float could be stuck(fuel pump assembly in tank) or the float could be holding gas(craked or has a hole in it) or like panda said,check the wiring
mikeSMASHES
12
Aug 30, 2011 06:57 PM
trevorjohn88ef
Feb 4, 2010 09:12 AM
tekniq
Jan 18, 2009 01:17 AM
actionfigure
Nov 17, 2005 12:04 PM
soopafly828
Mar 25, 2003 03:13 PM
