white smoke..... did a search already
Old Sep 26, 2002 | 09:15 PM
DuNkiN's Avatar
New User
Default white smoke..... did a search already
well heres what happen, my car was fine until i got some ic piping done. the next day it started puffing out white smoke when i started it up and started driving. that happened all day long, then i come to find out that the ic piping still had metal shavings inside casue it wasnt cleaned out good enough. but the smoking has calmed down and it only smokes when i drive it hard??? black smoke then white smoke......i dont know, ive been told several different things but im lost. im gonna get a compression test and leak down as soon as i can but i just need some ideas..... thankss
Old Sep 26, 2002 | 09:26 PM
MiraiZ's Avatar
Default Re: white smoke..... did a search already (DuNkiN)
I can think of a few things (some of which may be painful)
1. The shavings entered the combustion chamber and damaged your oil rings, or maybe even the head gasket. (long shot)
2. The shavings enter the combustion chamber and and is burning or melting.
3. Its all coincidence and your head gasket is blown...
Old Sep 27, 2002 | 06:22 AM
B00STeD's Avatar
Default Re: white smoke..... did a search already (MiraiZ)
oil rings or headgasket as stated above
Old Sep 27, 2002 | 06:33 AM
CovertFI's Avatar
Default Re: white smoke..... did a search already (B00STeD)
is this the first day you run with the turbo? because you said you got your ic pipes done.
Old Sep 27, 2002 | 09:58 PM
DuNkiN's Avatar
New User
Default Re: white smoke..... did a search already (CovertFI)
no its not, ive been turbo for 6 months now alteast..... i thought it was that but im hoping it'll fix itself just gotta wait and see what the tests show....i hope its the not rings or headgasket , thanks for the info
[Modified by DuNkiN, 10:58 PM 9/27/2002]
Old Sep 27, 2002 | 11:23 PM
madman604's Avatar
methinks blown headgasket. white smoke is a sign og water/coolant leaking into the cylinders. check your overflow bottle for bubbles while your engine is running. if you see bubbles, your HG is toast.
I dunno how metal shavings would do that tho...
Redprelude98
Nov 25, 2008 10:42 AM
mafia
Aug 17, 2007 05:58 PM
4drITR
May 3, 2006 09:13 PM
Randomlude
Oct 12, 2002 03:56 PM
All Motor EG
Jul 22, 2002 09:48 AM
