replacing rear quater panels on 95 accord wagon, are the sedan ones the same?
Old Mar 19, 2011 | 06:04 PM
SQ is the SQUAD's Avatar
Default replacing rear quater panels on 95 accord wagon, are the sedan ones the same?
so i finally settled for a hooptie accord wagon. its a 95 lx automatic. both rear quarters are gone. i plan on replacing both of them with either junkyard cut outs or ordering replacements online. my question is how different is the wagon rear quarter than the sedan.
this is the section i need to replace, not sure if its the same between the wagon and sedan
Old Mar 19, 2011 | 08:43 PM
Default Re: replacing rear quater panels on 95 accord wagon, are the sedan ones the same?
all the online quater replacement panels are for the 4 door sedan.
Old Mar 19, 2011 | 09:17 PM
wolfy47's Avatar
ther are very different....gl on your search for wagon panels
Old Mar 19, 2011 | 10:09 PM
GhostAccord's Avatar
Actually they look pretty similar in the area that you have highlighted.
Old Mar 20, 2011 | 08:10 AM
to me the highlighted areas look identical
Old Mar 20, 2011 | 08:25 AM
How much of the quarter are you looking to use? If you are only looking to replace a few inches of the wheel well portion. I would say that the sedan quarter would work.
Old Mar 20, 2011 | 06:44 PM
these pics are really too small to see
Old Mar 20, 2011 | 08:24 PM
wolfy47's Avatar
sedan/coupe rear ends are shorter while wagons are longer...closer to the top and towards the rear the panels go inwards while on the wagon they are more straight...placement of the antenna is also different
Old Mar 21, 2011 | 05:29 PM
but at what point does it change, or what part can i use.
Old Mar 22, 2011 | 05:07 PM
poorman212's Avatar
I think the manauls you can download (spoonertuner is what I have) have the body spec's. If you want some ruff measurements let me know (PM or post) and I will measure what I can for you-95 EX 4 dr. You can then use that compared to the measurements of the repalcement panels or your wagon and see? based on the pic's and a guess, the wagon "looks" to be about 6 inches longer to the tail lights than mine......
Old Mar 22, 2011 | 06:53 PM
IMO you would be pretty much good to go with the part you have outlined in the image. If you want to be more precise. You could take a few measurements of your wagon, i.e. from wheel well to body line, bumper to body line, door gap to tail light and match them up with a sedan.
fambern
Jan 18, 2009 04:30 PM
kenny_g
Dec 16, 2005 11:00 AM
deeweezy187
Apr 7, 2005 11:30 AM
fleetmack
Oct 15, 2004 03:30 PM
N3M3S1S_F0X
Audio / Security / Video
Aug 20, 2002 08:55 PM
