1991 Accord Erratic Idle
Old Mar 19, 2011 | 04:20 PM
campbmic's Avatar
Default 1991 Accord Erratic Idle
I bought a 91 Accord EX Station Wagon at a police auction a few months ago. Put a new battery in it and it started right up. The only problem is the idle instantly shoots to 3k then drops to 1.5k then shots back up to 3k and drops. This is just constantly going on the entire time. Like a ghost is revving the car haha.
Anyways, aside from a exorcism what else could fix this?
Old Mar 19, 2011 | 04:50 PM
accordmatt's Avatar
Default Re: 1991 Accord Erratic Idle
Either bad egr or worn vac lines and u need to replace. I would do both n full tune up
Old Mar 20, 2011 | 04:33 AM
poorman212's Avatar
As suggested by others. You can also check the FITV, after you'e confirmed the coolant is full.
Old Mar 20, 2011 | 08:39 AM
GhostAccord's Avatar
Air bubble in coolant = Bleed coolant
Vacuum leak - rotted hoses / gasket = Check for vacuum leaks
Dirty IAC valve = Clean IAC valve, throttle body & Intake manifold
Improperly adjusted FIT valve = Check adjustment of valve
There are two very descriptive threads in the FAQ that cover surging idle issues.
Cleaning the Intake air control valve (IAC) & throttle body
Fast Idle thermal valve (FIT) adjustment
Nicholas Mudd
Sep 29, 2015 07:55 PM
Dannyboy94
Feb 20, 2015 09:26 PM
ACCORD_1987
May 4, 2008 07:44 AM
speed1221
Mar 11, 2008 02:28 AM
Honda_Civic95_Ex
Jun 19, 2006 01:47 PM
