***NEED HELP***
i have some new feul injectors and i dont know how to put them in!! i have a 93 integra b18a1 motor the injectors are Delphi/Rochester 17113798
if any one can help hit me up!!
if they are oem standards then all you should have to do is remove the fuel injector wire harness that is on the top of the intake manifold by removing the 2 10mm bolts that hold it to the rail and the clips that hold the connectors to the injectors and then remove the 3 10mm bolts that hold the fuel rail to the injectors. once all that is removed then all you have to do is pull the injectors themselves and replace with new ones. Make sure that you replace all gaskets/seals with new ones properly and then replace the fuel rail and wire harness the same way you took it off.
thanks but these are not oem these are Delphi/Rochester 17113798
feul injectors the wiring harness will not fit on the injestors but i got told they would fit on that motor!!! any ideas!!
i know that they are not oem, what i was refering too was how much fuel they push out, to make sure they they will not be pumping more fuel then what is necessary. As for the wiring harness i would think you may need one that will fit, but do not quote me on this because i dont have too much experience with different injectors, so hopefully someone will come along that is much more knowledgable then myself. good luck man
B16Jacques
Jun 15, 2005 08:25 PM
