My driver's side power window and power locks don't work...need help!
Old Mar 19, 2011 | 08:03 AM
96blkteggy's Avatar
Default My driver's side power window and power locks don't work...need help!
Hello, I need some advice on this. My power driver's side window and power locks don't work on my 96 integra RS. Basically, I can operate the passenger side window just fine (Both from the driver's side passenger window switch and the switch on the passenger side door panel). The driver's side power mirror controls also work perfectly. However, when I press the driver's side window switch up or down, absolutely nothing happens. No clicking noises, no window motor noise, nothing. The same thing happens when I use the power lock switch...No clicking noise, no sound at all. I never had a problem like this but honestly it sounds like a few wires gave up on life to me. If anyone has a solution please share!
Thanks in advance!
Old Mar 19, 2011 | 08:13 AM
geetee74's Avatar
Default Re: My driver's side power window and power locks don't work...need help!
remove the switch and try to clean the contacts...it may work
Old Mar 19, 2011 | 08:49 AM
bark3rk20's Avatar
had the same thing happen to me a while back. Had to replace the whole window and lock switch with new ones before it would work. I would say try to clean the contacts.
Old Mar 19, 2011 | 03:19 PM
fcm's Avatar
fcm
Old Fart
Window and power door lock switch or broken leads in door to dash harness boot also possibly "A" pillar harness plug, [corrosion].
You will need a 12V test light or multimeter, pull the switches and test for power on the white/yellow lead going to the window switch assembly, [ign. switch on] if good test the red/yellow and red/blue leads at the switch, both should test as grounds, if they do, connect test light to both leads, ground terminal to one of the leads and probe to other lead, [it makes no diff. which way you do it], turn ign. on and rock the window switch for up and down test light should light up for both up and down, if it does the switch is good and motor is bad, if not the switch is bad, disassemble and clean and try again.
For the power door lock switch, test the black lead, should test as a ground at all times, rock the switch up for unlock and the green/red should test as ground, rock the switch down for lock and the green/white should test as ground, if so, switch is good. 94
92-CivicLX
Sep 23, 2013 07:46 AM
mugenpower92ls
Mar 23, 2007 05:50 PM
IDriveHonda
11
May 12, 2005 09:52 AM
sinister357
Sep 29, 2004 05:28 PM
Duck Sauce
Jan 29, 2002 11:27 AM
